Results 1 to 12 of 12
Thread: Automatic Shifter Gear Selector Shift Lug
    May 2012
    USA
    2000 BMW Z3 2.3 Auto
    Hi all,
    This is from my car
    This is what i found from internet
    See the circled area from my car? Why the shift lock lever is pressing against the range switch? Is that bend? Or the whole assembly frame is bent? The gear shift lever and the range switch gap is also more.
    Thanks..
    Jun 2016
    Odessa, TX
    2000 BMW Z3 2.8 Roadster
    I'll pop my surround and look real quick. About to head to work, so...
    Jun 2016
    Odessa, TX
    The yellow part is shifted over a little I think.
    May 2012
    USA
    I checked the yellow part. It is tight and does not look shifted. Might be wrong. Will check again
    Jun 2016
    Odessa, TX
    I reevaluated the images and it does seem that bit of metal is what's out of alignment. Check your transmission and engine mounts for wear, as that would allow the engine and transmission to sag to one side or twist slightly in relation to the chassis, dragging the support in the selector with it. I guess.
    May 2012
    USA
    Transmission mounts were replaced some time back (Lemforder - back in 2013 and now have 17k on them). Engine mounts, i think it is still the original. The XBrace almost touch the oil pan.
    The metal center part is bent. I don't think those parts need coding, and they litter junkyards, I would try a good used replacement and go from there. If you install a good straight part and the metal piece ends up sitting offset in that same way, then I'd look at mounts. But with new trans mounts I find it hard to imagine the engine leaning enough to cause the transmission to lean enough to move the lever that much. Your driver's side engine mount would have to be completely gone to allow that much movement, and even then, the trans mounts should prevent that flex from transferring to the shifter like that. I think the part just got damaged somehow
    PRICE CUT on ALL FABRICS
    May 2012
    USA
    I think it was like this even before the transmission mounts were replaced. Will look for a replacement part.
    Wonder how it got bent !!!
    Jun 2016
    Odessa, TX
    Gently lift the engine very very slightly (not much or the mounts will tear if not torn already) and look at the mounts for signs of tearing. They can split in half without causing any noticeable extra vibration or visible signs of tearing, apparently. Mine were both split in half when I got the car. I found out when I dropped the front crossmember after unbolting the mounts, and saw the bottom halves were still in the 'member.
    May 2012
    USA
    Actually i checked them few days back. It is aged and I think the mounts are worn. The pan is touching the X brace thing. May be i can put a thin paper in between them. That's it. On morning, it makes metal to metal sound on throttle. I thought it was the exhaust, but found it is coming from this area. Once warms up, it is fine.
    Didn't check it with engine lifted slightly. Need to try.
    Redding Calif
    1999 Z3 2.5L 5sp
    If the pan is almost touching the x-member, then I'd just replace the mounts... they're easy to do, and pretty inexpensive... the one trick I learned is: put jack with wood on top under pan, lift engine just a hint (1/4" maybe), and then undo the nut on the bottom of the mount, then unbolt the upper part from the block... then take the whole assembly out, swap the mount part, then put the new complete assembly in... if you don't unbolt from the block, you have to life the engine enough to clear the stud ends - risk to heater hoses etc, or you have to take the x-member off then have to support whole engine... but by unbolting from the block you don't have those problems.
    May 2012
    USA
    Unbolt the upper part from the block, never thought about it. Thanks Greg. All the videos i saw was to lift the engine high enough to take it out.
  1. automatic electronic gear shift selector question
    By zanella in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 08-22-2021, 05:40 PM
  2. Automatic Trans Gear selector rod seal +pics. How do you remove this darn thing!!
    By silver36 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-25-2017, 10:25 AM
  3. E36 E36 pistol grip automatic shifter, shifter plate, and gear shift switch, etc.
    By Baby ///M3 in forum Interior Lighting & Body Parts
    Last Post: 02-15-2015, 02:10 PM
  4. Automatic Trans gear selector lights
    By SprCpe in forum 1976 - 1989 (E24)
    Last Post: 04-13-2010, 05:46 PM
  5. Problems with Automatic gear selector..........
    By John540i in forum 1983 - 1991 (E30)
    Last Post: 03-30-2004, 01:23 PM
