I was looking at the vanos solenoids for e36s and they do not look like the one on my car. Mine looks like the one for a e38. Could this be why I have code p1519? I have a 97 m3.
Post a photo.
OBD2 M3 use this;
OBD1 are the same part just with a longer lead on them.
If your solenoid has zero wire and just a plug, then yes you have the wrong part... however if it is wired with polarity correct, it is likely the same functioning solenoid otherwise (depending on which solenoid exactly it is).
I switched over to the proper vanos solenoid and now I can hear and feel when it kicks in but still have the codes. I'm guessing I'll need to rebuild the spare vanos and put that on.
