Results 1 to 9 of 9
Thread: Reverse is going out on Tranny!
    Apr 2013
    Atlanta G.A.
    1997 BMW 840ci
    Hey Fellas, I got a question, my reverse is going out on my 97 840ci trans. I did some research on Realoem and got the
    item number and model number A5s440z. The model numbers are the same but the last four of the item numbers are
    different. Is it possible to use a tranny from a 97 540i inside my 840ci if I match the production dates between the two?
    Has anyone done this before and if so will the tranny mount and brace be a direct bolt up?
    Mar 2017
    Milwaukee, WI
    1996 BMW 850C1 M73
    If it is anything like the ZF 5hp30 transmission in the 850, the last three of the model number on the tag much match. I think it has to do with the bell housing.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    just overhaul the valve body, the small plastic ball is gone, have already done a lot https://www.bimmerforums.com/forum/s...se-gt-gt-fixed
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Yes, agree with Erich - the check-ball has worn to a point where it gets stuck in the oil passage!
    My BMW Repair YouTube Channel
    Apr 2013
    Atlanta G.A.
    1997 BMW 840ci
    Higgilo Thanks for the input. I wasn't sure but I figured if the last four numbers didn't match that something might be slightly different.
    I'll continue to do a little more research before I commit.
    Thanks again for taking the time to respond.
    Apr 2013
    Atlanta G.A.
    1997 BMW 840ci
    Thanks Tim & Shogun appreciate the info. Didn’t realize I never replied!
    Jan 2005
    Japan
    San Ramon, CA
    850Ci, M5, Model-S P85D
    Quote Originally Posted by shogun View Post
    The late model 840 (540 & 740 also) transmission is a 5HP24 (A5S440z).
    Not the same valve body.
    Jan 2005
    Japan
    actually does not matter, in general valve bodies need service, cleaning, replacement of wear parts, also on the 5HP24 transmissions we usually replace the balls, they are made of plastic too, there are filters/screens inside the valve body, small orifices, solenoid valves, all that http://www.bmwe34.net/E34main/Troubl...ch%20Guide.pdf
    here pics what we find on 5HP, see the measurement of the old check ball in the 5HP24 http://e32b12.blogspot.com/search/label/5HP24
  1. I think my tranny/torque converter is going out
    By ezbmr in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-25-2011, 05:19 PM
  2. Replies: 7
    Last Post: 02-24-2007, 10:22 AM
  3. cameron diaz is going out with justin timberlake...
    By ken_vs_ryu in forum Off-Topic
    Last Post: 07-02-2003, 04:59 PM
  4. help, i think my steering rack is going out
    By silverblueBM in forum 1992 - 1999 M3 (E36)
    Last Post: 04-10-2003, 06:11 PM
  5. Replies: 56
    Last Post: 01-27-2003, 12:58 AM
