Results 1 to 6 of 6
Thread: Winkfp doesn't update ecus after updating ecus
    Sep 2010
    Estonia
    2000 BMW 740i
    Hello. I'm using original ICOM with easyconnect mode OBD_ab625 and type remote". I've been trying to update E53 and E60, DDE and EGS. It goes all well and in the end, it says OK. But when I look in inpa ZB number, it's still the same as it was before. And when I try again to update, it still shows the same updateable ZB number as before. Is my winkfp setting wrong? I'm using the latest SP datens and latest winkfp.
    I've attached the settings picture below.
    Jul 2004
    Houston, TX
    36 Cylinders
    Check the UIF write boxes.
    You have actually been updating them, but it does not record the change to UIF area.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Sep 2010
    Estonia
    2000 BMW 740i
    All of them? If i actually updated them, why is the zusb number same as before? Even tought winkfp showed different number before programming. UIF?
    Jul 2004
    Houston, TX
    36 Cylinders
    Yes all of them until you specifically have a need to not write UIF.
    I saw the thread on cartechnology. You received lots of good answers there.
    UIF - user information field, which stores ZB, date, program, and VIN used at time of flash. Most of the time you have a limited amount of space for how many UIF slots fit, so there is a limit. (Unless you clear them yourself, most of the time a more difficult job.)
    -Abel
    Philadelphia, PA
    2005 M3 & 2004 330i
    UIF in comfort mode should be sufficient. The others only affect expert mode
    Sep 2010
    Estonia
    2000 BMW 740i
    Yes I did. Kudos. It all went good and I'm happy. Thanks for the replies 328 Power 04 (not to mention the odd name again)
    Also thanks TerraPhantm
  1. Updated shots after some hard work
    By jskicet in forum 1991 - 1999 (E36)
    Last Post: 04-01-2008, 10:35 PM
  2. *Updated Pics* After Detail & 2nd Coat of SG
    By bmwpowere36m3 in forum BMW Rides & Events
    Last Post: 07-20-2006, 01:07 PM
  3. Updated Pics after the new suspension
    By bimmerguy320 in forum 1975 - 1983 (E21)
    Last Post: 05-24-2006, 02:28 PM
  4. Updated Pics after the new suspension
    Last Post: 05-22-2006, 07:02 PM
