Results 1 to 11 of 11
Thread: SRS error 16 Analog Belt Drive
    Oct 2013
    Augusta, GA
    1999 Z3 M-Roadster, 2007
    I recently got INPA running on my laptop, "just in case." Turns out it was, "just in time."
    The SRS light came last Thursday night. I read the error, "16 Analog Belt Drive," and reset it. It came back on on Sunday night - same error message. Searched this forum for a clue and found nothing. A broader Google search produced nothing that was very useful. A search of the wiring diagram which has served me well in the past produced no clue as to where or what the "belt drive" is. Could it be the "pyrotechnical belt tensioner?"
    Has anybody seen this error and chased it down?
    Oct 2013
    Augusta, GA
    Have I stumped everyone?
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    Take apart the seat belt tensioner wiring connector and spray w contact cleaner. Reconnect and see if it will clear
    Jul 2004
    Houston, TX
    36 Cylinders
    Can you post some screenshots of your inpa? Or the part number of your airbag module? I searched through all the relevant airbag module DTC lists for E36 and none of them were anything close for code 16.
    All I found that was even maybe slightly close is for MRS2 airbag module generation, code 16 in decimal = 10 in hex: "belt lock driver"
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Oct 2013
    Augusta, GA
    Thanks for your reply Abel. I'm not ignoring you, just distracted by a sick tractor during planting season.
    Oct 2013
    Augusta, GA
    Here is a screen shot from INPA showing the error code 16 analog status belt lock driver (I missed the word "lock" in previous post):
    I also used my old B800 SRS tool. That error code from table 2 was 10 - Seat Belt Buckle Switch - Driver. Now I think I understand, both codes point to the driver's side seat belt. I suspect the "10" code in the B800 tool is in hexadecimal = 16 decimal. Could it be dirt in the seatbelt latch or some connector in that system?
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Correct on all accounts, and it's usually the connectors under the seat.
    Aug 2017
    Disconnect the connector under the seat, spray some electronics cleaner in there, plug it back and clear the codes of the airbag module.
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    FYI: my INPA told me it was driver side seat belt. Didn't have any cleaner handy, so I just pulled it apart and pushed it back together firmly. It worked.
    Oct 2013
    Augusta, GA
    Quote Originally Posted by me77 View Post
    I hate it when I chase a thread like this and never see the solution, so I'm closing the loop:
    I went so far as to find the wiring diagram and the specific connector that connects to the seat belt switch - a black 4 pin connector connected to three wires (BR/GN/WS, BL/VI/GE, & BR). I took it apart sprayed it with contact cleaner and reconnected. I also sprayed contact cleaner into the seat belt latch in the hope that I might clean the switch contacts should they be dirty. I reset the codes, and viola, problem solved.
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    Moisture + oxygen is a b!tch. Whenever I clean any of these contacts, I also add a dab of dielectric grease to hopefully eliminate the problem from ever occurring again. So far, batting 1000.
    Nathan in Denver
  1. Engine Misfires.. fuel? air leak? belt drive? help!
    By Etiennevb in forum 1999 - 2006 (E46)
    Last Post: 01-22-2008, 02:12 AM
  2. HELP!!! Belt Drive pulley
    By BMW1023i in forum 1996 - 2003 (E39)
    Last Post: 02-12-2007, 07:56 PM
  3. SRS Airbag Light / Seat Belt Issue HELP!!!
    By sphinxica in forum 1991 - 1999 (E36)
    Last Post: 04-02-2006, 04:16 PM
  4. Replies: 2
    Last Post: 01-17-2006, 07:12 PM
  5. A quick belt drive question
    By Kaiv in forum 1991 - 1999 (E36)
    Last Post: 11-25-2005, 12:02 AM
