RM European Auto Parts
Results 1 to 2 of 2
Thread: door lock repair kit issue
    Mar 2018
    Newport Beach
    2003 BMW 325i
    Greetings,
    I bought a door lock repair kit for my 2003 e46 in order to replace the spring which had broken. The problem I'm having is that, after re-assembling the unit, the key is hitting something in the chamber and will move only halfway forward.
    The kit pieces themselves don't seem to be the issue. I only replaced the spring and the pin. And before I apply pressure to the top of the assembly the key will move freely in and out.
    What I found is that applying pressure to the "shoulder" area of the piece (see linked photo at bottom) seems to push something into the chamber to block the key. If I relieve pressure from the shoulders I can wiggle the key until it once again moves freely in and out.
    If you've assembled a door repair kit you know that the mini plate that you slide over the loaded spring shoves those "shoulders" downward.
    Has anyone else experienced this issue? If so, what did you do to solve it?
    Thank you!
    https://1drv.ms/u/s!AgfH_QQMkypXgqEP1AW7x37Pq67VIw
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Chris Powell
    BMWCCA 274412
  1. Replies: 9
    Last Post: 01-20-2010, 01:20 PM
  2. Door Lock Repair Kit--e36
    By m.dystynkt.m in forum Exterior Lighting & Body Parts
    Last Post: 12-28-2007, 05:44 PM
  3. Door Lock Repair Kit
    By m.dystynkt.m in forum 1991 - 1999 (E36)
    Last Post: 12-06-2007, 08:14 PM
  4. Door Lock Repair Kit
    By 95werksm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-08-2007, 03:13 PM
  5. Door lock repair kit install
    By custom32 in forum 1983 - 1991 (E30)
    Last Post: 07-23-2005, 06:45 AM
