Results 1 to 14 of 14
Thread: Rearview Mirror Repair
    Chicago area
    too many....
    I tried searching but didn't come up with anything useful. I knocked the rearview mirror loose yesterday, and am wondering if there are any specific products to use to glue it back into the windshield with besides some generic rv mirror glue?
    Thanks again,
    Vince
    Jul 2010
    Nassau County, NY, USA
    2002 530i, 2001 325i
    Did you also knock off the piece that the mirror snaps onto on the windshield? If so, pop it off the mirror, and use rv mirror adhesive to re-affix. If not, and the mount is still on the windshield, just reinstall.
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Ditto...the mirror is mounted to a "button" that is adhered to the glass. If the button is still there...just turn the mirror at a 45° angle, then give it a quarter turn clockwise to lock the mirror into place on the button. The mirror is designed to dismount from the button when lightly bumped...this is to prevent the mirror from becoming an object one could be impaled on if in an accident:
    {remounting instructions}
    {removal instructions...a gentle bump toward the windshield}
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Mercedes does it the same too
    Feb 2014
    Alexandria, VA
    Speaking of mirror repair.... My M5 rear view mirror leaked it's oooz within itself, you know, the typical M5 rear view mirror issue, what outfit was it that does awesome repairs on them for a hunnerd bucks?
    Apr 2008
    Allentown, PA
    '03 M5; '98 911 C2S
    Quote Originally Posted by BimmrMeUpSnotty View Post
    I'm interested in the same information as my M5 mirror is now about 80% black. I didn't realize there was a repair option and bought a new one a few days ago.
    Does anyone have M5 mirror removal instructions similar to those above? The last time this happened to me was an Audi A6. It leaked fluid (nasty stuff) on the seat and then the shop broke the windshield trying to dismount the mirror.
    E24: moved to a new caretaker
    Feb 2014
    Alexandria, VA
    My mirror looks like a yellow fluid leaked between two pieces of glass, that is the typical issue that happens to them. Never seen your issue where it got dark. There is a place that fixes and guaranties the work for right around a hundred dollars.
    Los Angeles, CA
    Formerly 03' 540i
    radar-mirror.com
    2003 BMW 540i [Sterling Gray / Gray]
    [Msport] [Mods from A-Z] [Two-Tone Interior]
    Stuff For Sale :
    All types of E39 OEM Used HVAC Buttons
    Other E39 Parts, see my ebay! [Click]
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    Quote Originally Posted by Dking078 View Post
    radar-mirror.com
    +1, they do great work and can sometimes fix other issues with the mirror while they have it. Mine was missing the circuit board from inside the housing (assuming someone tried to repair it before and failed) and they had a spare and installed it, along with fixing the glass as well. Works great now.
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
    Feb 2014
    Alexandria, VA
    radar-mirror.com
    Ahhh yes.... That's the one! Thanks!!!
    (northeast) Indiana
    Quote Originally Posted by JimPA View Post
    The rear view mirror removal is the same...DO NOT TWIST to remove...you undo the cover (#5) from around the base (the rain sensor)...then you gently bump the mirror toward the windshield & it should pop off the mounting button. If you twist it to remove...you could end up misaligning the springs in the base that secures the mirror. You don't want to make the mirror loose...so bump to remove...then turn 45° to remount as explained in instructions above.
    If you have rain sensing wipers or the covers (#5) around the base of your mirror...just undo the covers & you'll see the removal is the same as the mirrors without the large base:
    Feb 2014
    Alexandria, VA
    Quote Originally Posted by Qsilver7 View Post
    Wow man, thanks for that. All these years, I've been twisting it to remove, so that was only for installation! At least I never broke any of them.
    (northeast) Indiana
    No problem. Probably 97% of the time twisting the mirror off would be okay...but then there will be that other 3% where the tension/spring mechanism in the mirror gets bent or out of alignment...then the mirror will keep falling off the mounting button because the "tension" isn't there to hold it securely. That's why I recommmend to just follow the instruction and "bump" the mirror to remove it.
    Apr 2008
    Allentown, PA
    '03 M5; '98 911 C2S
    Thank you Dking for the mirror repair link and Qsilver7 for the removal guidance. I was in NE Indiana (Berne) last month. I've had this car about three months and hope to deal with the mirror and several other small things before returning there to visit family in mid-May.
  1. Rearview mirror repair
    By WBAD530i in forum 1996 - 2003 (E39)
    Last Post: 09-21-2015, 12:14 AM
  2. Rearview mirror dimming pb. and repair
    By pauljcl in forum 1999 - 2006 (E46)
    Last Post: 10-15-2014, 11:31 AM
  3. How to repair rearview mirror?
    By ldwrols in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-03-2009, 02:33 PM
  4. manual dimming rearview mirror to autodimming
    By air in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-07-2002, 12:15 PM
  5. M3 Conv Rearview Mirror
    By ///MDriver in forum 2001 - 2006 M3 (E46)
    Last Post: 08-18-2002, 10:40 PM
