My rear drivers caliper is sticking on my X3 so I'm gonna replace that as well as doing the rear brake pads and sensor. Is there any reason to replace the rear passenger caliper as well.
Old school would be a yes, modern times it should be inspected while the other is replaced, but if it's good, then it's good. I don't hear about calipers locking up or leaking like they used to, but ymmv.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Using Tapatalk
I went with both. I didn't want to mess around with 2 different age calipers.
Couldn't you have just done a refresh kit? Was the caliper slider pin sticking or the actual piston?? If piston, then yes I'd probably just replace vs. messing with it.
