Results 1 to 6 of 6
Thread: Need help to idenify relays in m44 engine
    Feb 2018
    Post falls idaho
    1997 bmw 318i
    I need to figure this out so I was told that the purple relay which is on the very left of the 3 relays there. I replaced it and lots of bad things happened now I read in a electrical manual that that relay I changed thinking it was the fuel pump relay it says its the secondary air fuel pump and the middle one is the fuel pump relay in later models. Can anyone help me figure out if I'm using the right replacement fuel pump relay in the right spot or not? He's some photos. Thanks also the relay missing was purple.
    http://imgur.com/HemIm4I
    http://imgur.com/aNzAusw
    http://imgur.com/VE6hpC8
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    here you have the 1997 wiring diagrams for vehicles produced from 9/1996 till 8/1997, scroll down and you see all the relays https://www.bmwtechinfo.com/etm/data/e36/e36_97.pdf
    all years and models https://www.bmwtechinfo.com/etm/data/toc_cd2.pdf
    page 0670.0-00 shows the 3 relays in question, from left to right
    K6304 secondary air pump relay ( M3, 328i)
    K6301w fuel pump relay
    K6300 engine control module relay
    your VIN says EK24169 318i Sedan, USA version, built 06/1997, automatic transmission, M44 engine
    So if I understand that right, only M3 and 328i have this K6304 ?
    Feb 2018
    Post falls idaho
    1997 bmw 318i
    I am not sure man I'm trying to figure this out I was told the English ones have the secondary air pump as well because of emissions in USA. I'm not sure if this is correct or not what does this relay even do?
    Feb 2018
    Post falls idaho
    1997 bmw 318i
    Does anyone have any ideas? I'm very confused as shogun said its for m3 and 328 only but I have a m44 engine? I just don't wanna have to replace that wire again...
    Jan 2005
    Japan
    1997 E36 318 i/s/c, 328 i/c and the E36 M3 wiring diagram, and there only M3 and 328i have this relay http://wedophones.com/Manuals/BMW/19...g%20Manual.pdf
    1997 E36 /5 318ti ETM shows a secondary air pump relay with the note: late production http://wedophones.com/Manuals/BMW/19...g%20Manual.pdf
    from here http://wedophones.com/BMWManualsLead.htm
    maybe a electric expert can chime in
    Feb 2018
    Post falls idaho
    1997 bmw 318i
    Hopefully one can help me I'm confused as to what it even does for the car do I even need it??
  1. Need help to identify noise from my engine! (Video)
    By tommyngu in forum 1996 - 2003 (E39)
    Last Post: 02-01-2015, 03:47 PM
  2. guys need help to know whats in my car
    By deepocean in forum 1991 - 1999 (E36)
    Last Post: 10-26-2011, 08:19 AM
  3. Need help identifying this part in the engine compartment
    By damppooodle in forum 2004-2010 (E60,E61)
    Last Post: 10-25-2010, 11:35 AM
  4. Need help putting a 328 m52 obdII engine in to obdI 1993 318IS.
    By FLORIDADUDE727 in forum 1991 - 1999 (E36)
    Last Post: 06-29-2007, 03:44 PM
  5. Need help to buy engine... Thanks
    By Saul in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-25-2003, 02:34 PM
