Results 1 to 16 of 16
Thread: Sudden huge oil leak
    Oct 2016
    Kongsvinger Norway
    1999 BMW 528IA
    Exclamation Sudden huge oil leak
    I went to the gas station to fill up and wash the car. Parked the car and filled up, noticed a strip of oil starting 5 meters behind the car and a huge puddle under the engine. There's nothing when I look under the hood, looks like it came from under the intake manifold. Could the CCV just explode like that? Also I tried to turn the car over, it got a little but didn't stop like it seized. Could the cylinders be full of oil because of failed CCV?
    528iA 10/99
    Dec 2013
    Chicagoland area
    EXOTICS
    DO NOT ATTEMPT TO START THAT VEHICLE!!
    Have it towed to your favorite mechanic,
    or your own garage if you DIY,
    and up on a lift for inspection of damages.
    Check for loose oil pan drain bolt that may have fallen out.
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Pull the plugs out before you try to crank the engine over again.
    See if there is any oil coming out of the plug holes when you crank it.
    Los Gatos CA
    1987 325is, e34, Z3, e39
    Check the oil level. Verify that it's engine oil rather than transmission fluid.
    The CCV wouldn't likely explode, and it wouldn't likely dump oil.
    The oil filter housing gasket has been known to fail dramatically. It tends to squirt oil out under pressure, rather than dumping it out with the engine off.
    Oct 2016
    Kongsvinger Norway
    1999 BMW 528IA
    Luckily the gas station also has a shop and I know they're good, I got it towed around the corner and they're going to look at it today
    Quote Originally Posted by djb2 View Post
    I had checked the oil on Friday and it was fine, I checked it again right after it happened and it was dry
    Oct 2016
    Kongsvinger Norway
    1999 BMW 528IA
    I just had a thought, could it be a freeze plug on the oil filter housing? Looked like it fit with where the oil went on the crank case
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Here is your image of the housing and the DIY on the gasket repair process and the "Freeze Plug" repair and location for the 528.
    https://www.bimmerforums.com/forum/s...gs-quot-Repair
    No shop is going to do the freeze plug repair. They will just order the entire housing and the necessary OPS, gasket, antifreeze, oil filter, vanos oil line and crush washers, etc.
    If your P/S Reservoir and lines are leaking now is a GREAT time to replace them all as the area is wide open and easy access.
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Oops That was a later model Oil Housing. Here is the older 528 housing image
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    Oct 2016
    Kongsvinger Norway
    1999 BMW 528IA
    They managed to turn the engine today but not more than half a turn, is there still hope? I'm going to order everything for the S842A CCV, is there a dipstick tube that's insulated too?
    I'll probably take a look at it this weekend
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Hopefully they pulled the plugs FIRST. There is no CCV like the older models on your application I believe. The last years of the pre face lift could have had either.
    Update: Real OEM shows the older version for your application, not the new CCV as found on the 525 applications. On this one, is there any body left with all the salt you use on the roads? Rust has to be the largest challenge owning a 15 + Year old BMW in Norway.
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    Oct 2016
    Kongsvinger Norway
    1999 BMW 528IA
    Quote Originally Posted by StephenVA View Post
    Definitely! I'm planning to replace both rocker panels. Because of a stupid law we had until january this year cars with more horsepower were a lot more expensive, there's a lot of 520i and 520d on the road. that's why I want to keep mine.
    Would the cold climate CCV from the M54 fit my M52TU? This one: https://www.autoteile.de/en/product/V20-1872
    There's someone in Norway that retrofitted everything from the cold climate version. The Vaico kit and these pieces:
    11611440318 vacuum manifold
    13547504728 throttle body gasket
    11437531258 dipstick tube
    11431436293 dipstick
    13541435627 intake rubber piece
    That was on a M54B20, I'm guessing the gasket and maybe the rubber piece doesn't fit on mine? Are those necessary?
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    The set up is way different and there are not any issues with the older versions hydro locking in the USA. Now in Norway the average temps are way colder than Continental US. The trick is to confirm the lines are in good shape, not full of water/oil vapor goo ("Mayo" in US slang), replace them all as they are brittle and will break as soon as you touch them. At your age and mileage, I would do preventative replacement of all the CCV system parts using the cold weather ones. Image below.
    No. Description Supp. Qty From Up To Part Number Price Notes
    01 PRESSURE REGULATING VALVE 1 11617501566 $57.63
    For vehicles with
    Cold-climate version
    S842A=Yes
    01 PRESSURE REGULATING VALVE 1 11617533400 $65.78
    02 Vent pipe 1 11611432559 $25.73
    For vehicles with
    S842A=Yes
    02 Vent pipe 1 11617533398 $28.08
    03 Connecting line 1 11617504535 $33.87
    For vehicles with
    S842A=Yes
    03 Connecting line 1 11617533399 $33.87
    04 Vent hose 1 11157532649 $15.37
    For vehicles with
    S842A=Yes
    04 Vent hose 1 11157532629 $15.37
    05 Screw K60X22 2 11617533331 $0.75
    06 VACUUM HOSE BLACK 3,5X1,8 X 11727545323 $14.82
    07 Return pipe 1 11617504536 $33.8
    Now, if the vanos line is blown and leaking oil, that is a different issue. The question here is to test not stumble through a "let's see if we can get it started" attempt. A shop with BMW knowledge is way preferable than a butcher shop that is learning on your car. Approach any process they mention with care. Did they pull the plugs to confirm cyl are NOT full of oil. Oil/water will NOT compress, hence bent rods, busted head gaskets, etc, etc.
    Good luck.
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    Oct 2016
    Kongsvinger Norway
    1999 BMW 528IA
    I'm buying a cheap car today so I can fix it. Getting it towed to my shop and will take a look this weekend, first thing I'll do is to check the cylinders
    Oct 2016
    Kongsvinger Norway
    1999 BMW 528IA
    I finally had time to check it out. The return hose from the CCV to the dipstick tube had cracked and the vacuum line from the fuel rail to the CCV had snapped off. Looks like oil got sucked up to the valve and out through the hole in the hose and the point where the vacuum line connects. I'll check if there's oil in any cylinders tomorrow. I checked spark plug #2 and it was coated in oil
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Good luck with the inspection!
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    Oct 2016
    Kongsvinger Norway
    1999 BMW 528IA
    I got the intake off today, sucked up all the oil from cylinder 3 and 5 which the valves were open, sucked up oil from the ports on the head. I turned the engine manually and watched if the valves worked, everything works as far as I can see and I can turn the engine smoothly without much effort.
    I'll order a load of parts to replace vacuum lines, old plastic pipes, cold climate CCV with the new dipstick guide tube, also the starter since it's right there. I'll order a magnetic sump bolt and will do an oil change not long after I get it running again just to be safe.
    Can I clean the intake with gasoline? Can I do something with the breather hole on the power steering cap? the whole reservoir and both hoses are coated in fluid and dirt because of it.
    Here's a picture of the aftermath, at least it won't corrode like this
  1. Huge oil leak problem!!! Coming from this thing!
    By driftedtofu in forum 1992 - 1999 M3 (E36)
    Last Post: 06-30-2013, 11:45 AM
  2. HUGE oil leak this morning, HALP
    By AHenry014 in forum 1988 - 1996 (E34)
    Last Post: 08-22-2011, 12:55 PM
  3. huge oil leak
    By oputnik in forum 1996 - 2003 (E39)
    Last Post: 01-11-2010, 12:41 PM
  4. Watch out for cold weather (huge oil leak) 3.0i beware.
    By whatsaZ3coupe in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 03-02-2008, 11:15 AM
  5. HUGE oil leak HELP.
    By bloxsom in forum 1991 - 1999 (E36)
    Last Post: 02-05-2006, 05:17 PM
