Results 1 to 8 of 8
Thread: HELP!! My bmw is still not starting!!
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    Ok, so here goes....i own a 2000 bmw 323i. It wasnt giving me any heat so i decided to remove the intake manifold and replace the coolant lines that come out of the motor, and while i was in there i replaced the ccv. So in putting it back together i didnt tighten the throttle body connector and when turning on the car it gave me the dredded eml light and the triangle of death. So i tightened the throttle body correctly changed the plugs and still no start, it kind of wants to but doesnt... and still have the eml light and traingle of death...
    SO HELP!! please....i need it running...
    Craig.
    Ps and it ran fine before i took it apart!
    Jan 2016
    Ca
    2001 525it
    I would check all your work and make sure the connectors are tight. If the car ran before the work it should run now
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    Very true.any where i should look??? And which fuel line is supply and return blue or black??
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    Well, any ideas???
    Apr 2015
    Netherlands
    2000 E46 328i
    Quote Originally Posted by jclausen View Post
    ^ This. Plus, you can read the errors with an OBD-scanner/INPA to get a clue of what was not put back together correctly.
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    ^^^You dont think i did that???how about 10 or 15 times!!! and yes if i had one i would, but the forum says they arent relieble!!!so i guess ill take it apart again!!
    Apr 2015
    Netherlands
    2000 E46 328i
    That's not my experience. If you have a smartphone, you can pick up an ELM327 for under $5 and use an OBD-app to at least get some idea of the error codes you are getting. If it doesn't tell you the error, you can at least google the code it's giving, there are plenty of lists.
    Nicest solution is to have a laptop with INPA and corresponding cable which will give you detailed info on every ECU in your car; it's a must for anyone tinkering with these cars imo (and saves you money quickly since most dealers here charge $30 to read error codes).
    Feb 2018
    Star, Idaho 83669
    2000 BMW 323i
    Yes, i just ordered one from amazon...we will see....
  1. Replaced my starter and solenoid and my 1988 BMW 325i is still not starting.
    By Bmw1988Masons in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-21-2012, 05:44 AM
  2. please help my bmw is smoking
    By KIMBILL in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-23-2010, 01:49 PM
  3. Please help... My 325i Convertable will NOT start
    By mkosmos in forum Convertible Questions
    Last Post: 01-31-2008, 10:04 PM
  4. Help My Car Is Still Overheating...
    By Lucian1184 in forum 1991 - 1999 (E36)
    Last Post: 03-27-2005, 07:17 AM
  5. Help: My Steering is Still Tight.
    By bluemarlin in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-20-2003, 09:45 PM
