Results 1 to 6 of 6
Thread: Intake Manifold Removal?
    Oct 2015
    Mesa AZ
    1995 525i
    Hey,
    I have a 95 540i about 129k. The car has a bit of a rough idle when cold, very smooth when up to temp. No CEL. The PO did the CCV fairly recently. I am thinking it is the intake gaskets. Thoughts?
    Also, I am in the process of also doing valve cover gaskets, so I have some of that area apart. I have researched but cannot find a good tutorial on removing the manifold. Is there one around? It looks like it will be a bear.
    TIA, Mike
    Oct 2014
    Prescott, Az
    '95 540i/6
    The toughest part of remove and replace M60 intake manifold is the ccv tube. Otherwise it's pretty straight forward. Intake gaskets are a known vacuum leaking point. I'd encourage replacing hold down spacers and grommets as the grommets compress and dry out and have less clamping force on manifold to heads.
    Jun 2017
    Denver, CO
    325xi; 740i
    When I did the job the hardest part was just getting the wiring ducts out of the way which is a little cumbersome for the first timer. I don't recall if the e34 has the coolant res on the firewall but if that's the case just unbolt it and remove the overflow (left hose) and the level sensor connector and set the res to the side to get the most room.
    New Daily:
    2011 Audi A6 Avant 3.0T prestige. 1 of 368
    ----FOR SALE-----
    04 BMW 325xi 143k
    The Fun car:
    94' BMW 740i 308k miles
    Fresh 72k mile engine with all new seals. True E34 Manual Trans Engine Harness. 6spd Transmission Swap, Getrag 420G. RHD LW Single Mass Flywheel. E39 M5 Clutch. E39 M5 Shifter. Factory Car Phone. Factory 6CD Changer. Factory Electric Sunshade. Not So Factory Factory Electric/Heated Rear Seats. E38 Heater Valves. E43 M5 calipers/brakes
    Sold:
    1996 Oldsmobile Aurora; 194k miles but with a bad paint job and dented fender resulting in a payout to buy the 740i
    moroza's Avatar
    BFE
    E34T
    +1 to the above: straightforward, but expect a struggle from the wiring (especially where it connects to the injectors; you'll need a selection of pick tools to get the connectors loose) and the vent tube under the manifold. An unorthodox alternative might be to disconnect the engine harness from the e-box, leaving the wiring, fuel rail, and manifold assembled to each other.
    Oct 2015
    Mesa AZ
    1995 525i
    Thanks fellas
    Aug 2012
    Phoenix, az
    1995 540i/6; 1994 540i
    This YouTube video does a pretty good job of showing the process. https://www.youtube.com/watch?v=iIUfEoYvtuo
    When you have the intake off, be sure to replace the throttle body gasket and bolts (if they haven't be replaced yet with hex bolts). It's a whole lot easier than trying to do it later.
    '95 540i/6
    Swartz II
    250K miles
    '94 540iA
    Island Green
    178K miles
    '99 E39 540i
    190,000 miles
  1. Intake manifold remove and reinstall
    By martialartsblac in forum 1991 - 1999 (E36)
    Last Post: 11-15-2006, 11:51 AM
  2. M42 Intake Manifold removal
    By Sarc in forum 1991 - 1999 (E36)
    Last Post: 10-27-2005, 03:34 PM
  3. intake manifold removal, gas lines?
    By anylouder in forum 1991 - 1999 (E36)
    Last Post: 06-06-2005, 08:08 PM
  4. Intake Manifold removal
    By atlantisvip in forum 1991 - 1999 (E36)
    Last Post: 04-30-2004, 09:08 PM
  5. Clutch install easier with Intake Manifold removed?
    By vjlax18 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-23-2004, 03:09 PM
