Results 1 to 3 of 3
Thread: M40b18 running rich and missfires
    Jan 2018
    lithuania
    1996 BMW E38
    Hi, so i have an issue with my e36, the engine is m40b18 and it missfires bad. So i changed:
    Fuel pump
    Spark plugs
    Spark leads
    Ignition coil
    Crank sensor
    Maf
    O2 snesor
    And nothing helped, starts good, ibdont think that the timing belt hoped
    I willka add a video for more clearence
    https://youtu.be/3yEUA3WKcA8
    Jun 2010
    NY
    1997 328i
    Change to another gas station and put better gas, use a couple bottles of fuel injector cleaner over the next couple of tanks.
    One or more injectors may be leaking.
    Jan 2018
    lithuania
    1996 BMW E38
    Thanks for your reply. Injectors was replaced
  1. Running Rich and bucking... :X
    By mk2core in forum 1983 - 1991 (E30)
    Last Post: 09-10-2008, 12:22 PM
  2. Running Rich and Idle
    By Homegrown in BC in forum 1975 - 1983 (E21)
    Last Post: 03-20-2008, 09:03 AM
  3. Running rich and idling rough
    By Racerhoze in forum 1988 - 1996 (E34)
    Last Post: 11-02-2007, 05:06 PM
  4. Running Rich and don't know why
    By hecuter in forum 1992 - 1999 M3 (E36)
    Last Post: 09-01-2007, 12:57 AM
  5. Replies: 9
    Last Post: 05-16-2003, 03:53 PM
