Results 1 to 21 of 21
Thread: How to get the airbag light off when you have race seats?
    Jul 2010
    baldwin, ny
    2003 540MSPORT 6 #861
    Trying to figure out how to remove the cluster airbag light from dash once you remove the stock seats ???? Is it just a matter if the seat belts or the moduLe not plugged in ?
    2003 540MSPORT #861/1265 -GF71249 .Black Sapphire Metallic/Sandbeige.Dinan intake~M60 manifold
    Spec racing stage 2+ clutch and custom light flywheel .M5 rear LSD 3:15~M5 driveshaft ~Rogue Octane SSK
    36K ENGINE SWAP!!!.~Rogue thrust arm bushings~Rogue studds~Dinan strut bar
    EIBACH front/rear sway bars with BEASTPOWER brackets~CDV delete~Redline fluids/Racing blue Ate~ APEX EC7 RIMS SQUARE 18 x 10's~M Pararallel rims 9.5 all around~285 30 18 rears~265 35 18 fronts~ENKIE 18x10's square with Continental Slicks 275's square~RE 11's, 595 RSR's~BC racing coil overs 8k/6K~Steel braided brake lines~Powder Coated valve covers-A1 headers 100 cell cats, performance resonator and 4
    cross tips, CUSTOM BBK - MASSIVE HATS AND BRACKETS - AERO-6 WILDWOOD-, ANODIZED CALIPERS STAINLESS STEEL PISTONS THERMAL TREATED, CUSTOM WILDWOOD ROTORS 14.50
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Both sides? If you already have removed your OE seats and have the airbag light on you'll need an SRS reset tool to clear it.
    The pass seat has an occupancy sensor as well as the seat belt connection.
    Ebay sells a plug-in module to defeat the occupancy sensor.
    Drivers seat AFAIK only has a seat belt connection to worry about.
    Jul 2010
    baldwin, ny
    tks Jim - right now have the passenger side out and might as well replace with race seat on both sides and save some weight - yup I can reset myself but will look on ebay for that plug in - good suggestion
    Oct 2003
    Seattle
    99 M3
    You need modules for all three sensors - occupant, passenger seat belt, drivers seat belt before the light can be reset. Otherwise it illuminate immediately upon start-up.
    Jul 2010
    baldwin, ny
    I tell ya I can never catch a break from this car - we put the passenger seat back in the stock one just so we could go to a car show low and behold darn airbag light won't go off !!! What's more the luxury cable for the seat belt won't go back on lol - will see if just unhooking the battery and rehooking will do - always something never a dull moment
    Feb 2014
    Caboolture, Q, Australia
    E39 535i
    The only airbag error that will reset itself is the passenger occupancy sensor.
    The others you'll need to reset with a compatible scan tool.
    Sent from my G8141 using Tapatalk
    Jul 2010
    baldwin, ny
    Munich little code reader picked up no codes - there are no codes or errors lol though why does BMW work so hard against us - so your telling me I need a "special" reset tool lol this is absurd I just literally unplugged and replugged a perfectly running seat bmw can kiss my rear !
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Whaaaaaaa..... Jeezuz.
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Stop complaining Mel. Your whining is above compare. We are all here to help you.
    Jul 2010
    baldwin, ny
    Quote Originally Posted by philly98540 View Post
    ditto HELP
    JimLev's Avatar
    Sundance Mesa, NM
    Mel, you need a dedicated SRS tool to reset it. Dope slap coming your way.
    Feb 2014
    E39 535i
    You may need to use INPA or another tool that is specifically designed to reset airbag warning systems because the seatbelt pretensioners were unplugged.
    Those codes won't reset themselves like the seat occupancy sensor will.
    It's not an issue that BMW specific either.
    Any vehicle fitted with airbags will require a specialist reset when any critical component like an airbag or a pretensioner is unplugged.
    Jul 2010
    baldwin, ny
    ahhhh SRS LOL WHEW I thought I had to sacrifice my first born to the mighty BMW GOD LOL. They do this on purpose don't they!
    Jul 2010
    baldwin, ny
    Quote Originally Posted by StRaNgEdAyS View Post
    Thank you - the Gm products don't have these none sense issues unplug re plug as many times no need to do these what BMW invented $$$$$$$$ dealer marketing $$$$$$$ can't stand BMW computers
    Feb 2014
    E39 535i
    My Holden 1998 Calais (an Australian GM product) required the airbag light to be reset with an SRS compatible tool when the airbag was disconnected to replace the steering wheel...
    And I remember my 2000 Fairmont (Australian Ford) also requiring the use of an SRS compatible tool to reset the warning lights when it needed a new dashboard because of cracking in the plastic.
    So the need for a specialist rest tool (not necessarily BMW specific) isn't unusual when dealing with these systems.
    Any SRS compatible service tool should be capable of resetting the warnings.
    Jul 2010
    baldwin, ny
    not the NEW ones - I have the inside deal on that- so I have to spend $$$ needless to say for something that had no fault at all this is a VALID complaint - cant wait for the day this BMW sees the junk yard or something
    Jul 2010
    baldwin, ny
    Update - $17 srs tool and done - still a silly procedure by BMW none the less
    Dec 2012
    Georgetown, TX
    2002 540i Touring Sport
    Cool. Didn't see if it was mentioned, but Next time either disconnect the batt before or don't turn your key to access. position while the harness is unplugged at anytime. Same thing happened to me. I knew it from the get go, but forgot about it. Needed to move my seat back with power and used the key instead of shutting the doors and reopening to reset the standby power to seats.
    ...Dooh! You have race seats. Disregard
    Ed
    ________________________________________________
    -2002 540iT Sport-
    Previous Bimmers. - 2000 540iA Sport | 2000 540i6 Sport | 2000 M5 | 2000 740i customized | 2000 323Ci | [Bikes 2012 f800GS | 2014 R1200GS]
    Current Stable - 2011 VW Touareg TDi | 2016 Mazda 3 Hatch | 2019 Ram 2500 6.4L Hemi 4x4 Big Horn Off-Road
    Keep on modding and fixing!..
    Feb 2018
    butler county, ohio
    2006 325i
    Quote Originally Posted by evomel View Post
    what SRS reset tool did you get to achieve "off" of the SRS light?
    and where did you get it?
    thanks for any info you can give me as our s is on as well for seemingly no reason.
    JimLev's Avatar
    Sundance Mesa, NM
    Quote Originally Posted by SOLOLUCKY View Post
    You could have a bad seat occupancy sensor.
    https://www.amazon.com/s/ref=nb_sb_n...words=B800+SRS
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    It is a near certainty that there is a perfectly good reason and that that reason is some wire or connector or component is failed.
    In theory you can code out equipment in the SRS (MRS) main module.
    In reality that module is very very cranky about being recoded and when you try to "uncheck" equipment the module sometimes will brick.
    For most people, just fixing the damn stuff properly is the way to go.
    If you really wanted to try to code stuff out (race seats etc.) it can be tried but I'd do it with a couple junkyard spare modules in hand and not try coding my 'good one' ... (and actually my MRS module is a JY unit already...)
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  1. How to get Check Engine Light off??
    By Giants9595 in forum 1995 - 2001 (E38)
    Last Post: 01-12-2010, 01:20 PM
  2. How to get the side trim off??
    By MTHRAR in forum 1992 - 1999 M3 (E36)
    Last Post: 07-21-2007, 12:46 PM
  3. Help Getting Wires To The Trunk...how To Get The Rear Backrest Off
    By 325rider in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 11-26-2005, 08:54 PM
  4. How do you get the airbag light off??
    By Stang_ROTY in forum 1991 - 1999 (E36)
    Last Post: 12-28-2003, 04:12 PM
  5. How to get the brake handle off?
    By Stylin in forum 1991 - 1999 (E36)
    Last Post: 11-14-2001, 06:33 PM
