Results 1 to 6 of 6
Thread: 7x15 BBS Mahle wheel bolt size
    Mar 2018
    NY
    1979 e21 Baur
    Just tried installing a set of original 15” BBS RA Mahle basketweaves on my 1979 Baur but the bolts I have are too short. Can anyone tell me what the correct bolt size/length is for these? Any help appreciated. Link to image below. Thanks!
    http://pasteboard.co/HcnLJKY.jpg
    Oct 2015
    RI
    1983 320is S52/2003 VR6T
    I have a set on my car and I have IE's 80mm extended studs and I don't have much extra stud left over when the wheel is on.
    http://www.iemotorsport.com/mm5/merc...E12x80threadin
    Feb 2008
    NY
    Motorsport hardware sells stud conversion kits.
    https://motorsporthardware.com/produ...nversion-kits/
    Turner sells longer bolts.
    https://www.turnermotorsport.com/p-3...w-mini/?pdk=AQ
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    Really pathetic how they don't bother to actually give the length. You're supposed to guess based on the p/n I suppose.
    Standard/Stock Size (#TWH995128B) ($27.50)
    In Stock
    Bolt For 3mm Wheel Spacer (#TWH995128B) ($27.50)
    In Stock
    Bolt For 5-8mm Wheel Spacer (#TWH995132B) ($28.90)
    In Stock
    Bolt For 10mm Wheel Spacer (#TWH995135B) ($29.50)
    In Stock
    Bolt For 12mm-12.5mm Wheel Spacer (#TWH995139B) ($29.50)
    In Stock
    Bolt For 15mm Wheel Spacer (#TWH995143B) ($29.50)
    In Stock
    Bolt For 18mm Wheel Spacer (#TWH995143B) ($29.50)
    In Stock
    Bolt For 20mm Wheel Spacer (#TWH995145B) ($29.50)
    In Stock
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    The stock wheel bolt extends 21.5 mm out the back after it passes through the wheel. That's what you want. If you use a thicker wheel, or use a spacer get a longer bolt, such that it will still extend 21.5mm (or thereabouts) out the back when put through the wheel hole.
    Sep 2015
    Massachusetts
    E21 327i, E46 325iT/5
    Quote Originally Posted by okieflats View Post
    In Stock
    In Stock
    In Stock
    In Stock
    In Stock
    In Stock
    In Stock
    In Stock
    28mm
    32mm
    35mm
    39mm
    43mm
    45mm
    From the part number like you said.
  1. WTB: 1 or 2 13x6 BBS Mahle wheels
    By Cagedbunny in forum Wheels and Tires
    Last Post: 11-08-2006, 12:43 PM
  2. Will E21 BBS Mahle wheels fit?
    By newfan in forum 1983 - 1991 (E30)
    Last Post: 02-18-2006, 12:47 PM
  3. wheel bolt size
    By lovesm3s in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 09-18-2005, 02:19 PM
  4. Wheel bolt size
    By Steve530 in forum 1991 - 1999 (E36)
    Last Post: 07-22-2004, 10:50 PM
  5. steering wheel bolt size...
    By incubus in forum 1992 - 1999 M3 (E36)
    Last Post: 12-05-2003, 06:31 PM
