Results 1 to 13 of 13
Thread: S54 Oil Pump Install, No Oil Pressure
    Atlanta
    M3
    I installed a VAC S54 upgraded oil pump on my S52 and I’m not getting oil pressure, as indicated at the oil filter (idiot light + gauge).
    After we got everything back together and filled with oil, we dry cranked the engine (pulled fuel pump relay) a handful of times, and then ran the engine a couple of times for ~15sec at a time. No oil pressure.
    We then got concerned that we had done something wrong, so we pulled the pan and pump again and it was all installed correctly.
    Turning the oil pump by hand out of the car we were able to pump oil, so I’m confident that oil is flowing, but for some reason we’re not getting pressure.
    Does anyone have any thoughts on this? Could the pressure relief valve in the pump be defective? Do we need to give it more time to pressurize?
    Edit for future Googlers: Prime your pump before you install it
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Sender wires reversed or sender not grounding to block? Is the pump primed — you might be able to direct oil into it through a port in the filter housing. I had an issue with that on a rebuilt S52 years ago and had to pour some oil in from above, which was not very convenient.
    Atlanta
    M3
    Pressure gauge worked a couple of days ago, before we swapped pumps. Lifter ticking also confirms the low pressure.
    We actually tried pulling the oil filter and pouring some oil in there. When we cranked the engine with the filter off nothing came up into the housing (although I admit I don’t know if it should)
    ithaca Ny
    95m3/97m345/powerstroke
    Are you using the s54 sprocket or s52 sprocket?
    Richmond, VA
    E82 128i, E36 M3
    Quote Originally Posted by Pat533i View Post
    Good question. Should be the S52 sprocket.
    For reference, I recently did this and oil pressure is pretty low at idle which I knew would happen from research before decided to go this route. I see 7-10 psi via my AiM MXL2 dash when warm at idle.
    Atlanta
    M3
    S52 sprocket.
    We have pressure! We ended up running a bunch of oil through it on the bench to prime it.
    Jan 2003
    San Diego
    #94 IP, '68 250SE '17 M3
    Quote Originally Posted by Steage View Post
    It definitely should shoot out the cap. Husband was helping me finish up an oil change on my race car. He forgot to tighten the filter cap and my engine bay got covered within a matter of seconds after start-up.
    S52 sprocket.
    '94 325is #94 IP/GTS3 Mauritius Blue Metallic
    "And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high." - Ayrton Senna
    Mar 2018
    Gainesville, Florida
    1997 BMW 528i
    i cant firgure out how to post my own thread this website is impossible to use and i need answers
    Jan 2003
    San Diego
    Quote Originally Posted by JayJay39 View Post
    I don't believe you can start a thread when you a super new, but maybe I'm wrong.
    Oct 2005
    Auckland, New Zealand
    BMW 97 M3 3.2 Euro
    When I had my sump off (S50B32 ) I primed the oil pump with vasoline. Took approx 15 turns of the key for the pressure to register on my gauge. Nerve racking.
    Glad you got it sorted
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    It appears that you figured out how to start your own thread, here.
    88M3 AW 43k miles Project FS
    NeilM is offline Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    Yes. The basic procedure is both to pre-fill the pump and to pour oil into every appropriate engine orifice you can think of. When you start the engine, run it up to 2K rpm with no load and clench all your own orifices while hoping that oil pressure is indeed about to happen. This is something of an act of faith, but neither cranking nor idle rpm are sufficient to draw oil into a system that's been completely drained and not primed.
    Neil
    Nov 2001
    Parker, Colorado
    GTS3 E36, 97 M3/4/5
    Just did this over the past weekend. Newly built S52 with S54 pan and pump setup. Pulled the spark plugs. Pulled the coils. Unplugged the power to the injectors. With the valve cover off, poured oil over the head, coating the cams and lifters (about 4 qts). Poured oil over the vanos and associated chains and sprockets (1 qt). Filled the oil filter housing and poured down the center tube of the housing. switched on the main power and cranked the motor over for several minutes (stopping every 30 seconds so as not to overheat the starter). Didn't build any pressure.
    Added my last quart directly down the center of the oil filter housing tube and cranked again and got 15lbs of pressure on the gauge. Buttoned the car up (installed plugs, coils, valve cover and plugged in injector harness) and started the car up with solid oil pressure.
    Was definitely nerve racking as all that cranking with no pressure showing up after the owner spent all that $$ on a new motor. All was good in the end.
  1. S50 euro and S54 oil pump instal on M50/M52/M54
    By Kurtisja in forum 1991 - 1999 (E36)
    Last Post: 07-31-2016, 10:06 PM
  2. S54 Oil Pump w/ E34 Oil Pan
    By said in forum Engine Conversions
    Last Post: 03-28-2014, 01:12 PM
  3. M20 Oil Pump Install
    By tjse30 in forum 1983 - 1991 (E30)
    Last Post: 07-04-2011, 10:12 PM
  4. S54 Pan/Pump installed...question about oil pressure.
    By vinnymac in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 02-12-2009, 05:26 PM
  5. Modify oil pump to incresae oil pressure?
    By M52 POWER! in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-05-2008, 09:43 PM
