Results 1 to 4 of 4
Thread: 01' 325i RPMs still drop after some maintenance
    Feb 2017
    Grass Valley, CA
    2001 BMW 325i Sedan
    So for the past couple months I noticed a rough idle coming to a stop and just in general (dipping below 500 then back up to 6-700), so I cleaned my ICV, MAF while I was at it, and just today replaced plugs.
    I've watched it in every instance that I can when putting in the clutch, and it is still dropping down and then back up, except now at least without shuddering or sounding like its bogging. Not sure if it would do anything but also tried disconnecting the battery for any sort of reset fix.
    Currently at 169k miles. Any ideas on things to check out?
    May 2010
    Honolulu, Hawaii
    '73 E9, '94 E34, '02 E46
    I think the fuel/air mix is all to c*ck, specifically much too lean. You're looking for an intake leak which may/not whistle at you (literally, they sound like that). Or a smoke test by a pro.
    Also, of course, there's "Mechanic's Rule": look at what you did last.
    Anyone else?
    Charlie
    Your mission, should you decide to accept it, is to add value to these threads, either by pictures or by descriptions, so the next person with the same or similar problem stands on your shoulders.
    Feb 2017
    Grass Valley, CA
    2001 BMW 325i Sedan
    Don't know how but I forgot to add that I have a P0455 code (didn't think it could be related), and when filling my tank gas manages to leak to the ground (which my shop mentioned a smoke test for). Does this tie into the fuel/air ratio issue?
    Also an intake leak may be a part of it because I have noticed a slight whistle when pushing it before, just didn't think too much of it.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Yes, a leak in the Evap system will cause you to run lean.
    The most common culprit for leaks is the Upper and lower intake boot. Most cannot see the lower boot leaks as it is way down in the car, as the upper is much easier to see. Next will be the CCV system, as by now anything that is plastic if very brittle so check that too.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  1. '01 540i RPMS slowly drop while driving
    By johrt in forum 1996 - 2003 (E39)
    Last Post: 04-18-2018, 08:23 PM
  2. E46 01 325I Sedan No heat after overhaul
    By haes70 in forum 1999 - 2006 (E46)
    Last Post: 01-21-2015, 08:03 PM
  3. Cleaned the ICV, but rpm will still drop..
    By Plagueoc in forum 1992 - 1999 M3 (E36)
    Last Post: 06-13-2008, 09:38 PM
  4. EML Code -- still there after some work...
    By thumper300zx in forum 1988 - 1994 (E32)
    Last Post: 08-09-2007, 01:49 AM
  5. Discovery after some routine maintenance...
    By M triple in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 07-03-2005, 03:32 AM
