Results 1 to 10 of 10
Thread: Just to be clear, There is No Way to siphon oil from the top of the engine?
    Huntington Beach, CA
    06 Z4
    So, my 2006 Z4 3.0 si is very soon due for an oil change and last time I changed it I went under and opened the little trapdoor and poured out the oil that way
    Since then I have a pump for siphoning oil through the dipstick tube which works great for my other cars but since I'm lead to understand the Z4 doesn't have a dipstick, even if it doesn't, does it have a dipstick tube or any other way I could get a siphoning hose to the bottom of the oil pan from above the engine?
    Put it simply, I dislike getting dirty and I avoid crawling underneath cars when I can avoid it, of course if it's unavoidable, so be it. But is it?
    It's never the fuse.
    Houston or thereabout
    '13 M3 Coupe
    This is how I ended up changing the oil on my Z4MC almost every time. It was great not having to get under the car.
    2013 BMW M3 Coupe : Interlagos Blue : Silver Norvillo : 6MT : Competition Package
    pics of M3
    06 Z4
    Wait, so are you telling me that the Z4 DOES have a dipstick tube or some other way to get a siphoning tube from overhead?
    '13 M3 Coupe
    Yes, I am. Like I said, on my E86 M I used a siphon tube through the dipstick tube.
    pics of M3
    06 Z4
    Any chance you could take a photo or describe what the dipstick tube looks like so that I don't confuse it for something else?
    06 Z4
    I just looked at my N52B30 engine and I didn't see anything there that quite seemed to pass for a dipstick tube.
    '13 M3 Coupe
    I don't own the E86 Z4 M Coupe any longer. But if you have the N52B30 (3.0i), then you're right -- no dipstick. Sorry dude.
    pics of M3
    06 Z4
    Well, on these cars, it's not like it's something I have to do often.
    Mar 2011
    Southwest, Ohio
    2007 Z4 3.0Si
    Quote Originally Posted by Georgeous View Post
    I looked in to this shortly after I bought the car because I had never owned a car without a dip stick to pull.
    What I was told was that there is no way to use the existing hole on the block to install a tube/dipstick because there was something else under where that would be.
    I believe it was something that was part of or maybe the entire unit of the electronic pickup for the computer to tell me on the dash?
    It's annoying and it is one of the very few things I don't care for about the car.
    Dean
    Arlington, VA
    2000 Z3 Coupe, M Coupé
    The Ms have a different engine than the Zs. If you have a Z with an N52, there’s no dipstick and, as far as I can tell, no factory designed way to install one. I dislike the design choice, but seem to have absolutely no influence with BMW’s decision makers.
  1. Is there really no way to recover a gamertag...
    By thought in forum Video Gaming
    Last Post: 01-07-2010, 08:16 AM
  2. Small door lock issue. I know there is a way to fix it.
    By BMW323iDude in forum 1999 - 2006 (E46)
    Last Post: 12-18-2007, 05:25 AM
  3. There is NO WAY i just fried my amp is there?!?!?!?!?
    By xjeeper in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-16-2007, 10:41 PM
  4. there is no way this is a z9.
    By ken_vs_ryu in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-15-2007, 02:07 AM
