RM European Auto Parts
Results 1 to 13 of 13
Thread: '01 Z3 cannot communicate with DME
    NW suburban Chicago
    hiss by my window
    SOLVED '01 Z3 cannot communicate with DME
    Two different generic p code readers cannot communicate with this car's DME. It is giving an occasional trans fault warning light that is always gone when I see the car.
    Of more immediate concern is that the emissions testing station cannot communicate with it either so it has failed smog. NO "check engine" light on, car runs fine.
    Any thoughts?
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    random question - you may have done this already.
    is this via OBD-II port?
    is the 20-pin cap installed - tight?
    Jun 2005
    Dirty MFin Jersey
    M3 Buildup
    check for ground at dme pins 4,5,6 12v at pins 7, 8 , 26
    Buy my native installed ISIS ISTA-D/ISTA-P bmw diagnostic laptop. More Info Here!
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    As shadowpuck has indicated, you should make sure that the cap on the underhood diagnostic port is in place. Also, you should find someone with an adapter for the 20-pin plug underhood, and try connecting there. At least find out whether you can communicate with the DME through that port....this is important. At the very least, if you can communicate through that port, and have an adapter, the emissions testing/inspection machine will actually work just fine, plugged into the 20-pin port.
    Can you communicate with the EGS? Does the CEL actually work?
    Chris Powell
    BMWCCA 274412
    Jun 2005
    Dirty MFin Jersey
    M3 Buildup
    missed the part of the car running. Definetly check 20 pin port. You can wire direct to this without adapter should you need to in a pinch. Check voltage drop across k-line from 20 pin and/or obd port to dme as well if cap is on proper and still no comm.
    NW suburban Chicago
    hiss by my window
    Thanks for some ideas.
    No communication with anything, DME or EGS
    I'll try to get my hands on the car today and check the under hood diag. port and the DME pins as suggested.
    It would be nice if it were a loose cap on the 20 pin
    Thanks all, will advise progress.
    Jun 2002
    E39M5, E500 4WD
    I had a quick look at the diagrams, Ross.
    Pin 1 of the 20-pin connector receives the data from the DME, and also the EGS and several other modules.This is a black wire.
    Pin 2 of the 20 pin connector goes to the OBD 16-pin connector at its pin #7. This is a white/violet/yellow wire. I see no other connection between the DME and the OBD connector.
    I cannot see it in the diagrams, but my guess would be that the cap is bridging pin 1 to pin 2 .
    Chris Powell
    BMWCCA 274412
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Chris, weren't there some M and Z models that had a recall for this exact issue? Also, on the E38, there is a fuse for the ports that have caused this in the past. It doesn't show up on the fuse list in the car. Think it's F25 on our cars.
    Jun 2002
    E39M5, E500 4WD
    Fuse 31 would be for this car's OBD. Fuse 26 for the 20 pin. Maybe, just maybe the 20 pin's power failed, but I don't think this would cause communication failure at the 16 pin connector. And the failure of power at the 16 pin would cause the generic OBD tool to fail to activate at all, I believe. As for a recall, well, maybe.....I'll see what I can find, I don't remember anything , but there's a whole lot of stuff I don't know......
    Chris Powell
    BMWCCA 274412
    NW suburban Chicago
    hiss by my window
    Alright, you guys will love this one.
    SO, the 20 pin cap was loose. A pin from a Peake tool had come off and remained in the 20 pin socket preventing the cap from closing which was pretty obvious.
    Car owner's nickname is Magoo.
    Thanks for the help.
    Jun 2002
    E39M5, E500 4WD
    Hey, the problem is solved....trouble is, the blind Mr. Magoo is driving again. Glad I live far away!
    I hope he tipped you, for going well above and beyond the call of duty.
    SHADOWPUCK: GREAT CALL !!!
    Chris Powell
    BMWCCA 274412
    NW suburban Chicago
    hiss by my window
    Yes, thanks to Shadowpuck I now know why there are shorting pins in that cap.
    This was for dear friends so no remuneration beyond coffee and cake. MRS Magoo is back on the road in her Z3. MR Magoo drives an MB, with the left blinker continuously on.
    Mar 2003
    St. Joseph, Mo.
    awesome! i'm glad it was an easy fix! i had to extract a peake pin once on my track car - so, this reminded me of that....
  1. bmw e39 cannot communicate with any modules except DME
    By wice in forum Diagnostic Software
    Last Post: 06-30-2023, 05:04 PM
  2. 01 Z3 Coupe CEL with P0171 & P0174
    By SG Simmons in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-03-2017, 12:26 PM
  3. no crank, so start, no communication with DME, EWS or EGS HELP!
    By neonphire8604 in forum 1996 - 2003 (E39)
    Last Post: 07-03-2014, 01:39 AM
  4. Car cranks but won't start. Error E10 (can't communicate with DME)
    By trustydrip in forum 1992 - 1999 M3 (E36)
    Last Post: 05-01-2012, 05:07 PM
  5. Cannot Communicate With ECU-Swapping Clusters??
    By ChiTownTy in forum 1988 - 1996 (E34)
    Last Post: 11-07-2011, 01:13 PM
