Originally Posted by
E21M10
Hello, i am looking for some infos to choose the right parts for my engine setup. Engine is a 318i coming from an E30. Its a pre catalytic version with 9.5 compression. Plan is to stay with the single carb to keep an original look. Here its starts to get a bit difficult for me. Carb of choice would be a weber register 32/36 or a 38/38 double downdraft. As i understand the 38/38 is the one for more performance than the 32/36. A Schrick Camshaft would be the next step: but schrick say for a single carb engine the 284 is the max to go with. As i remember some of you are running a 292 cam with a single carb and it seems that it works? By the way exhaust system will be a free flow 2.25" martelius one. Here in germany the single carb versions are not so often done so i hope to get some informations by this way. Greets andreas
32/36 not sure what max would be but I have heard of a schrick 292. Not sure how it ran in person but apparently it's been done. The 38/38 I've heard and seen up to a 304 schrick. Mostly race car 2002's that move on to 45mm dcoe's. Eventually with a single down draft carb you'll have too much reversion ie spitting more fuel backwards through the carb. I went with Steve's suggestion from TEP on the 294 they offer for this reason.
Eh I went on the 2002faq board and see you've a response from Jeff already. Good to go then Was going to say should post there too.
88 M3
91 318is
91 318i
83 320is
08 X3 3.0si
"If it flys, floats, or f*cks, rent it!"
