Results 1 to 7 of 7
Thread: 2000 E46 instrument panel stalk problem
    Jan 2018
    Sachse, TX
    several
    I was changing the time using the right side stalk on my instrument panel, but found it difficult to get traction when turning. Anyone have this issue? Not sure if I can replace the stalk or if the problem is with the instrument panel itself.
    Sent from my SM-G930V using Tapatalk
    Jeremy
    2000 323Ci Titansilber Metallic cabriolet
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    The stalk has little arms that often break. Its a dumb design, but that's the case in your situation. The solution is to buy a spare cluster, disassemble it, and replace yours with the stock from the spare. Careful they are very brittle.
    Jan 2018
    Sachse, TX
    several
    Quote Originally Posted by dhurley34 View Post
    Is that the only way to set the time? Dang. Too much trouble.
    Jeremy
    May 2009
    DK
    325i
    Quote Originally Posted by JCC511 View Post
    You can set it using e.g NavCoder.
    Jan 2018
    Sachse, TX
    several
    Quote Originally Posted by bvli View Post
    I do not have a BMW nav. Does that matter?
    Jeremy
    Jan 2018
    Sachse, TX
    several
    Video just posted by the 50s Kid with a fix!
    https://youtu.be/J3kPO_VeHwM
    Jeremy
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Go to E46Fanatics and search there. Someone there has a solution other than a second clustet.
  1. E46 Instrument Cluster weird problems..
    By Bazsi96 in forum 1999 - 2006 (E46)
    Last Post: 12-05-2016, 01:22 PM
  2. 2000 e46 328ci side mirror problem/fault
    By Hrenowsky in forum 1999 - 2006 (E46)
    Last Post: 03-20-2016, 01:08 PM
  3. E46 2000 BMW e46 Instrument cluster
    By prezesklubuBMW in forum Interior Lighting & Body Parts
    Last Post: 11-25-2010, 08:19 PM
  4. Oem Xenon problem 328ci 2000 e46
    By also111 in forum 1999 - 2006 (E46)
    Last Post: 01-03-2009, 10:14 PM
  5. Instrument Panel Problems
    By hightcn in forum 1992 - 1999 M3 (E36)
    Last Post: 11-28-2005, 12:08 PM
