Results 1 to 25 of 28
Thread: Oil Leak
    Jul 2011
    canada
    2001 BMW Z3 2.5i
    Oil Leak
    Hi 2011 2.5I Z3
    Shop said last fall I have a oil leak on the oil pan gasket.
    They they could remove oil pan and replace gasket without removing the motor.
    I am wondering if that is possible?
    And if so is there any thing I should look at replacing of the parts that they have to remove to get to the oil pan and what should they check inside the engine when they remove the oil pan
    Thanks for everybody help
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    The oil pan gasket is an easy job for someone with experience and tools. Drop the suspension cross member, move the ps pump, remove oil pan. However, over the years I have found most oil pan leaks to actually be a mis diagnosed oil filter housing leak.
    Jul 2011
    canada
    2001 BMW Z3 2.5i
    I Had The oil stand gasket fixed in 2016
    They said it look like it was leaking by the bell housing
    But when I look under the car it looks like it is leaking form the the front of the engine
    which would be the where the oil filter is
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Another very common source for an oil leak is the 32mm cap over the timing chain tensioner (RH/front); snugged one up today.
    Jul 2011
    canada
    2001 BMW Z3 2.5i
    I will Have to check for that when I get the car out of storage.
    If it is the oil pan
    Is there any thing I should look replacing as they take parts off to get to the oil pan?
    Jan 2017
    orlando,fl
    2000 2.3l z3
    Maybe the oil pump nut thing ?
    SW Florida
    Quote Originally Posted by Geoz3 View Post
    Engine mounts; they're right there, and you're already undoing one (1) end of them anyway. They definitely deteriorate over time__they're rubber, and rubber never stops curing, it just keeps getting harder and harder.
    Indianapolis
    F30 328d X-Drive
    I replaced my oil pan gasket last year and did not remove the motor. I did support the motor with a hoist though because I pulled the front cross member out and replaced the motor mounts at the same time.
    1995 Mazda RX-7 Feed Widebody LS3 6-speed (Toy, project)
    2010 Cadillac Escalade Luxury (Daily, Pulls my 18' car hauler)
    2014 BMW 328d XDrive (Wife's Daily)
    Have owned 4 other BWM's I no longer have.
    Jan 2017
    Dallas, tx, USA
    2000 BMW z3
    Engine wash it. Put UV dye. Check for leaks after a few days.
    Jul 2011
    canada
    2001 BMW Z3 2.5i
    Thanks for the reply's guys I will keep you updated as to what I find when I get the car out
    Right now they are saying maybe plus 2 C by next Monday I need more heat before I take the car out
    Jul 2011
    canada
    2001 BMW Z3 2.5i
    Uncovered car today check under the car and it does look like it leaking from oil pan by the bell housing.
    But what is leaking out of the front I do not know it seems that the spot in the picture has dried up you can still see residue on the floor.
    I just can not figure out what it is.
    It does not look like antifreeze there is a slight oily residue but I do not know what can evaporate and leave an oily residue
    Jul 2011
    canada
    2001 BMW Z3 2.5i
    Oil Leak
    Well I got the car out yesterday
    Attached is a picture of the leaks
    The one at the top of the picture is the oil pan gasket by the bell housing
    The one at the bottom is a leak that I do not know what it is
    It is a clear fluid it does not seem like oil but is slippery does not look like anti freeze
    Any Ideas?
    Feb 2014
    Galt,CA
    2002 M Coupe
    power steering fluid?
    Marty
    Jul 2011
    canada
    2001 BMW Z3 2.5i
    The power steering fluid is red this fluid is clear
    Dec 2007
    Great Dismal Swamp
    Engine oil, power steering, coolant are the three main leaks. If automatic, add the transmission cooler.
    /.randy
    SW Florida
    What's it taste like...?
    The only fluid that should be clear__though rarely is__would be brake fluid. I think you'd better figure out where it's coming from (my money is on clutch slave)!
    The chances of it being water droplets from the A/C being on are __% ???
    PRICE CUT on ALL FABRICS
    Dec 2007
    Great Dismal Swamp
    Clutch, brake, and A/C aren't at the front, per post 11.
    /.randy
    Jul 2011
    canada
    2001 BMW Z3 2.5i
    Randy
    It taste a little sweet at first and then gets bitter
    If you look at the first pic
    it looks like it is leaking right under the rack & pinion steering
    Where on the car would the Clutch Slave be located?
    Also took off power steering cap yesterday and the oil is red but milky colored ( which means air could be getting into the system I think)
    George
    SW Florida
    Pretty common for the little elbow to leak where it connects to the w/washer pump__that could taste sweet (I just use water/alcohol in my cars, as it smells just like the fluid they came with when they were new).
    That's at the front...
    Dec 2007
    Great Dismal Swamp
    Quote Originally Posted by Randy Forbes View Post
    Me too, but I do because it burns better.
    /.randy
    Jul 2011
    canada
    2001 BMW Z3 2.5i
    Randy
    what you describe has been replaced already and the fluid is clear my washer fluid is green
    At any rate I will be taking car in to see if the shop can shed some light on where the leak is coming from
    George
    Camden, NY
    2006 BMW 325xi
    Finally getting weather for open cockpit driving. Backed my '01 3.0 Auto out of the garage today with two oil spots found on the floor. Degreased the floor and underside of undercarriage and placed a piece of clean cardboard under the engine/tranny. Two days later two distinct oil spots on the cardboard. Jacked the front end up and used a borescope under and above the engine in an attempt to fine the origin of the leak(s). Not very conclusive. I also needed to renew my inspection so I asked my mechanic if he could take a look while the car was on the lift. His assessment was the leak was coming from somewhere in the upper part of the engine. So oil filter housing, timing chain plug, valve cover are all suspect. Need to remove all plastics and take a peek. It's close to needing an oil change and I want the leak taken care of before that. More later. Very good thread giving me possible solutions for the symptoms exhibited.
    Ebby
    2011 328xi
    2006 325xi
    2001 Z3 3.0i
    1998 325i
    Jul 2011
    canada
    2001 BMW Z3 2.5i
    Just took some pics from behind front driver side wheel if you look at the picture you can see two drips on the rubber boot what is above that could be leaking
    oops pic upside down
    May 2013
    USA
    2001 Z3 3.0/5 roadster
    Or a torn boot full of water if you drive in the rain. When I replaced my boots/tie rods one side was very rusted under the boot. The other side was pristine
  1. Amsoil 0/30W = oil leaks?
    By Uber328 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-22-2002, 06:16 PM
  2. What is this (oil leak?)?
    By M3Nut in forum 1992 - 1999 M3 (E36)
    Last Post: 05-13-2002, 11:40 PM
  3. Help! Questions about oil leak and CPO coverage.
    By ToddGT in forum 1991 - 1999 (E36)
    Last Post: 09-17-2001, 12:01 PM
  4. I found my Oil Leak! (sorry kinda long)
    By M3Jokster in forum 1992 - 1999 M3 (E36)
    Last Post: 08-14-2001, 03:50 PM
  5. oil leak......lost 1/2 quart in 300 miles
    Last Post: 08-08-2001, 01:10 PM
