A pillars are try new windshield in front - no rain or snow for two days yet dripping water from this open drain now all day !!! Looks like from center console - any place water would be getting stored and then leaking out???
2003 540MSPORT #861/1265 -GF71249 .Black Sapphire Metallic/Sandbeige.Dinan intake~M60 manifold
Spec racing stage 2+ clutch and custom light flywheel .M5 rear LSD 3:15~M5 driveshaft ~Rogue Octane SSK
36K ENGINE SWAP!!!.~Rogue thrust arm bushings~Rogue studds~Dinan strut bar
EIBACH front/rear sway bars with BEASTPOWER brackets~CDV delete~Redline fluids/Racing blue Ate~ APEX EC7 RIMS SQUARE 18 x 10's~M Pararallel rims 9.5 all around~285 30 18 rears~265 35 18 fronts~ENKIE 18x10's square with Continental Slicks 275's square~RE 11's, 595 RSR's~BC racing coil overs 8k/6K~Steel braided brake lines~Powder Coated valve covers-A1 headers 100 cell cats, performance resonator and 4”cross tips, CUSTOM BBK - MASSIVE HATS AND BRACKETS - AERO-6 WILDWOOD-, ANODIZED CALIPERS STAINLESS STEEL PISTONS THERMAL TREATED, CUSTOM WILDWOOD ROTORS 14.50”
Whoa. That's some serious Engrish right there.
The AC evaporator coil drains could be plugged. Your new windshield (I think) could have been poorly installed.
And if your carpets were wet, then it will take quite a while for the water to all leave.
Nate J.
(oOO\ (|||)º(|||) /OOo)
(eŌō\ (||||)º(||||) / ōŌe)
It is water and not coolant, right? One of the pix looks a bit blue.
Ed CT
1998 528i
5-Speed
Aspen Silver
Aubergine Leather
Nate J.
If it's water, take a look under the driver side wiper motor for a hole where the throttle cable would go through the firewall into the cabin. It should have a little plastic cap plugged in. On my wagon, which always had drive-by-wire, that cap was removed for some reason and I was getting a ridiculous amount of water collecting under the carpets. At one point, we pulled 5 gallons of water just out of the driver side rear footwell, and it turns out there was quite a bit more under the front footwell that had spilled over to fill up the rear. Worth a check at least.
-Paul
2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers, Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
2006 Porsche Cayman S - Soul Performance Competition Headers and Exhaust, H&R Coilovers, 718 Boxster Spyder wheels, Rennline 35mm rear spacers
thank you Paul I'm going to look at that one as well - wow - I've pulled so much foam and carpet it's starting to look like a race car LOL
Definitely not coolant but water - the color was like that cause of ages of poooling - sorry for the bag English lol was flustered when writing gotta go back and edit that lol
Update that water I think was older residual left over - as of today no NEW water zero and I tested top down no leaks - so what I saw dripping out was older water- removed one more drain plug on rear floor to help
Nate J.
