Results 1 to 16 of 16
Thread: 94.540i6 dies when warm
    Sep 2016
    Niagara
    1995 525i, 1994 540i6
    Need some help.
    The car runs fine when cold. Once warmed to ot it won't hold an idle. Soon as I need to slow down it shuts down. And will not start for 10 minutes or so. If I drive with the gas peddle down and keep the rpms at 1000 it will get me home. The stomp test says 1221 over and over. Would a 02 sensor cause this?
    Where to start? Is this a common problem maybe some of you have had?
    moroza's Avatar
    BFE
    E34T
    O2 sensors will affect idle but not usually to the point that it won't idle at all. Is it running ok at higher RPM? Decent fuel consumption? No black smoke or bad smell? Assuming yes to all three, your O2 sensors are fine. Most likely, you have an intake leak. The symptoms are typical of one, and the M60 is known for leaking intake gaskets in particular (also PCV plate and main intake hose). Best way is a smoke test - either whip out your bong, or borrow a fog machine and get creative, or pay for an actual shop with an actual tech to use an actual smoke tester that costs 10 times what it should. If the intake is airtight, test the fuel pressure. Report back.
    Oct 2014
    Prescott, Az
    '95 540i/6
    Thoroughly clean the IAC, inspect intake boot for tears downstream of the MAF. Check for vacuum leaks.
    Sep 2016
    Niagara
    Ya it runs great as long as you don't let it idle when hot. IAC ?
    moroza's Avatar
    BFE
    E34T
    Idle Air Control (valve).
    Sep 2016
    Niagara
    Ah yes old shakey. I will test and clean it.
    Then blow a few grams through the bong.
    Sep 2016
    Niagara
    Looks like my rear main seal is leaking.
    Would that cause a stall?
    moroza's Avatar
    BFE
    E34T
    No.
    Sep 2016
    Niagara
    So just the intake leaks will affect idle. OK
    I need to find a fuel psi gauge.
    moroza's Avatar
    BFE
    E34T
    Well, lots of things will affect idle, but a leaking seal is an unlikely source.
    Sep 2016
    Niagara
    Well I killed the battery last night trying to start it. So I am going to start with the fuel pump tonight. Got one from rock auto in 2 days
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by 95525ibob View Post
    Killed the battery so ordered a fuel pump?
    You did blow a few grams through the old bonger, didn't you?
    Sep 2016
    Niagara
    Yep and no leaks. Now it won't start at all so going with the fuel pump install.
    Feb 2012
    Greatest City
    95 547i
    cats might be clogged. same thing happened to my ex-friends car
    Sep 2016
    Niagara
    Nope. I run wide open 2.5 pipes with Mos port chip
    Sep 2016
    Niagara
    Finally found it. Dme relay
    7 dollar part. Weeks of down time.
  1. car dies when warming up
    By eduardopepe in forum 1999 - 2006 (E46)
    Last Post: 01-21-2008, 05:49 AM
  2. 89 325i dies when warming up
    By MattPark in forum 1983 - 1991 (E30)
    Last Post: 01-06-2005, 06:51 PM
  3. E 46 That dies when warmed up!
    By mjsoos in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-15-2004, 02:07 PM
  4. E30 engine dying when warm. Long post.
    By logantv in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-23-2003, 10:35 AM
