Results 1 to 5 of 5
    Mar 2018
    Russellville, KY
    2005 BMW X5 4.4
    Air ride suspention light
    I am installing coils in the rear of my X5. Is there a way to shut off the Air ride suspension lights on the dash. I only have rear air bags and someone before rigged up a switch to work the compressor, I am not sure what was wrong with it before, and for the money, The coils are a more cost effective way to go.
    Thanks in advance
    Nov 2016
    Pasadena CA, USA
    09 X5
    Can you use bmw scanners?
    Carly App, ISTA or INPA should be able to clear it.
    Mar 2018
    Russellville, KY
    2005 BMW X5 4.4
    No, I do not have access....
    Nov 2016
    Pasadena CA, USA
    09 X5
    If you’re tech savvy enough, it takes only a cable (Kdcan cable on Amazon or eBay) to setup INPA. Install INPA on your PC laptop , and you have a powerful tool in your toolbox!
    INPA is (reportedly) the BMW factory diagnostics tool. It reads and erases fault codes, and resets various adaptations.
    Other option is Carly for BMW.
    Google them for more information.
    You're going to have to have software capable of coding it out of the vehicle, so the control units in charge will ignore the air ride system and not turn on the warning lamp.
  1. Air Bag Dash Light?
    By LEEK323IC in forum 1991 - 1999 (E36)
    Last Post: 02-06-2007, 11:49 PM
  2. Air duct fog light covers?
    By M3M3M3 in forum 2001 - 2006 M3 (E46)
    Last Post: 01-06-2007, 07:44 PM
  3. Unfiltered Air - Check Engine Light
    By ///M3 XTC in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-22-2004, 06:26 AM
  4. Air Bag warning light from swap to 1999 steering wheel
    By Sean in forum 1992 - 1999 M3 (E36)
    Last Post: 11-17-2003, 12:05 PM
  5. Is rear air ride suspension standard on all X5s?
    By roc-x in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 11-03-2003, 11:53 PM
