so I go to hook up my oil pressure sensor and i notice theres another wire thats similar , one has one wire and is shorter the other is longer and has two wires, which goes to what? ( also i completely forget which goes to the oil pressure whoops)
May have to clean them and try to see the colors. Here's a copy of the wire diagrams for the '79.
1979
http://www.findmymerchant.com/images...l/ETM_1979.pdf
fyi: be aware the 'service interval switch' ties into the oil light wiring.
Tbd
28943488_1990321751229994_402688119_o.jpgtheres a picture if that helps at all
thank you, now the other question is what does that go to because ive spend a long time looking for something that that would go to, with my luck its probably right infront of my face
