Results 1 to 6 of 6
Thread: Xenon Headlight Intermittent Failure
    Dec 2010
    Van Alstyne, TX
    2006 BMW Z4 3.0si 6MT
    I've done a couple of searches and haven't returned any results. So here goes.
    I have Xenon headlights on my 2006 Z4 3.0si. The left headlight was replaced on December 27, 2014 because it was not working. Now the left headlight intermittently does not work. Would this possibly be because the Igniter or Control Unit is starting to fail? Does anyone have any ideas?
    Thanks for the help!
    Brian
    2006 BMW Z4 3.0si Premium/Sport
    "Life is fun with the top down!"
    You replaced the entire headlight when it stopped working? How do you know it was not just a bulb?
    Sounds like it just needs new bulbs to me
    PRICE CUT on ALL FABRICS
    Jul 2018
    NE Ohio
    2007 Z4 3.0si Roadster
    I'm digging up a old one here, but I have the same issue. Did you solve it? Was it just a bad bulb?
    Feb 2013
    FL
    2007 BMW Z4 E85 3.0 SI
    You can use the bulb and igniter of the opposite side to test. Switch the bulbs first, then the igniters, then the ballast. The problem will follow the defective component wherever it goes!
    If none of these components prove defective then it could be the internal wire harness of the headlight, the headlight socket or the ALSZ (LCM).
    Jul 2018
    NE Ohio
    Thank you
    Feb 2013
    FL
    Just make sure to put the cover back on each time. I left mine off one time because I was going back the next day and didn’t want to struggle with the cover more than once. Sure enough it rained that night and my headlight was full of water the next day. The water also got into the ballast which had to be replaced!
  1. Intermittent xenon headlight
    By bimas in forum 1996 - 2003 (E39)
    Last Post: 02-28-2017, 01:33 AM
  2. 740 HID Headlight Intermittent Failure
    By 740Sport in forum 1995 - 2001 (E38)
    Last Post: 12-28-2010, 11:44 PM
  3. Xenon Headlight Failure/Auto Leveling
    By severecaraddict in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 10-12-2008, 09:55 AM
  4. OBC lowbeam failure with OEM xenon headlights?
    By Gizmo330iT in forum 1999 - 2006 (E46)
    Last Post: 02-16-2008, 01:44 PM
  5. Intermittent Xenon headlight problem (2000 323i sedan)
    By alokoko in forum 1999 - 2006 (E46)
    Last Post: 11-27-2006, 08:50 PM
