Results 1 to 13 of 13
Thread: Both lower control arms.
    Mar 2018
    Austin,TX
    2005 BMW 325Ci
    Mine was a 05 325Ci, Firestone gave a quote for $1,027 for replacement of CTRL ARM W/BALL JNT. Is that really expensive? how hard is that to do yourself?
    Mar 2016
    Portland, OR
    2002 325Ci Cabriolet
    Quote Originally Posted by bimmerRAJ View Post
    Firestone gave a quote for $1,027 for replacement of CTRL ARM W/BALL JNT. is that really expensive? How hard that is to do ourself?
    That seems fair including the parts but I'd want to know WHAT BRAND they intend to use. As for doing the job yourself, it's not hard if you have access to a lift. In the garage or driveway on jack stands would be a real PITA in my opinion. I replaced my FCAB's after purchase but I had lift access - and its a job I would not have attempted without.
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    May 2010
    Honolulu, Hawaii
    '73 E9, '94 E34, '02 E46
    Just do it. You'll need some healthy torque:1/2" drive metric sockets, to be able to separate ball joints (pickle fork or two hammers) and get a front end alignment after.
    There are various kits available for the work, i like to go to fcpeuro.com and I owe them nothing.
    Charlie
    Your mission, should you decide to accept it, is to add value to these threads, either by pictures or by descriptions, so the next person with the same or similar problem stands on your shoulders.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The new arms and bushings should be Meyle HD. They seem to last the longest amount of time.
    Mar 2018
    Austin,TX
    2005 BMW 325Ci
    Quote Originally Posted by All2kool View Post
    IDK I thought that was expensive and left the place.
    Mar 2018
    Austin,TX
    2005 BMW 325Ci
    This is awesome, very nice thank you.
    Mar 2018
    Austin,TX
    2005 BMW 325Ci
    Considered.
    Mar 2010
    Fredericksburg VA
    '00 328Ci, '18 330xi
    Do it yourself. Not hard at all. You'll need a pickle fork. A 21mm socket and a 3' extension (for getting to the center control arm nut from the top of the engine, much easier than trying to get it from the bottom.) Replace your control arms and front control arm bushings at the same time.
    This is a easy job on jack stands. Don't be scared.
    Mar 2018
    Austin,TX
    2005 BMW 325Ci
    Quote Originally Posted by mdfiasco View Post
    thank you very much
    Aug 2013
    1999 BMW M3 Coupe
    I recommend one of these things instead of a pickle fork:
    https://www.harborfreight.com/3-4-qu...tor-99849.html
    Less work than hammering on the fork, and it should kill even the most firmly attached joints.
    Mar 2017
    Norwich, Connecticut.
    E46 wag. E36 convertible
    I have a 'stick-it' note posted above my computer from over the past 10 years...It reminds me to NEVER purchase any German suspension part produced from MEYLE!
    Dec 2013
    Chicagoland area
    EXOTICS
    I have not experienced any problems with parts labeled Meyle-HD.
    Maybe you are referring to Myle original parts.
  1. CO WTB Driver fender, driver lower control arm, both knuckles with bearings (prefer M3)
    By jeepster in forum Great Plains & Rocky Mountains - US
    Last Post: 06-06-2012, 01:45 AM
  2. WTB: both front lower control arms 96-99 M3
    By das borgen in forum BMW Parts Wanted
    Last Post: 10-21-2009, 06:43 PM
  3. Replies: 11
    Last Post: 10-11-2009, 11:03 PM
  4. I somehow bent both rear control arms..
    By Cannon in forum 1992 - 1999 M3 (E36)
    Last Post: 06-14-2001, 06:36 AM
  5. How many labor hours to replace lower control arm bushings?
    By Kritpoon in forum 1992 - 1999 M3 (E36)
    Last Post: 04-17-2001, 01:41 AM
