Results 1 to 20 of 20
Thread: E36 M3 Missfire sounds like a camed V8
    Aug 2017
    Staten Island
    2016 328I lease, 1998 m3
    Hi Everyone, I'm pretty new to the forums and am having issues with my E36 M3,
    So, about a month ago I had pushed the car further than I had before and reached about 140 (closed course ofcourse) as I was slowing down tho the car stalled out on me on the highway. It wasn't much of a problem I chucked it into neutral and restarted but it was not happy, because of school I had to let it sit for about a month thh till now to really dig into it.
    It, had a P0301 code initially, so I just decided to swap the coil pack from cylinder 1 to cylinder 2
    Now I have a,
    P0302
    P0301
    P0300
    So both cylinder 1 and 2 are missfireing now,
    I had replaced all of the spark plugs about 2500 miles ago when I first got the car. The car sounds like a camed V8 on startup and stalls out after less than 30 seconds sometimes it lasts nore more, pretty much just enough time to read the codes.
    Anyone have any thoughts it would be much appreciated.
    Best,
    Sent from my SM-N950U using Tapatalk
    Aug 2014
    Redwood Shores, CA
    1999 BMW M3 Coupe
    So you swapped your ignition coil from cyl 1 to cyl 2 and now you have a misfire for cyl 2. Fairly safe to say your ignition coil is the problem.
    Aug 2017
    Staten Island
    Quote Originally Posted by th3turk View Post
    cylinder 2 did have a missfire code but cylinder 1 also threw a missfire code, this is where I'm confused
    Aug 2017
    Staten Island
    While this is true cylinder 1 still had a missfire even after swaping in the good coil, just not sure where to look next for this.
    Aug 2014
    Redwood Shores, CA
    1999 BMW M3 Coupe
    Did you actually reset the codes after swapping ignition coils? If not, the code for cyl1 will still remain even if you arenít still misfiring cyl1
    Tampa, FL
    97 E36M3 S54
    If the car is on the orignals I'd just get 6 new ignition coils and go from there.
    Aug 2017
    Staten Island
    Hmm, I'm not sure if I did clear the codes, I will do this once i get home thank you.
    As for swapping all 6 coils I'm going to be swapping just the one for the time being and seeing if that fixes it given moneys tight thanks to school atm, once the summer internship comes around and the cash starts to flow again rest assured that the rest will be replaced, at this point I'm trying to get her up and running again.
    Tampa, FL
    97 E36M3 S54
    Aug 2017
    Staten Island
    So, Update,
    I picked up a duralast coil from autozone for the time being to even see if I can get the car running,
    She starts Stutters and shakes the entire car in the process before soon after stalling out
    Both Cylinder 1 and 2 are throwing codes again after clearing them,
    Jul 2012
    Atlanta, Georgia
    Infiniti FX37, E36 M3a/4
    Do a compression test.
    I help the less fortunate; http://ourrescue.org
    Feb 2009
    Santa Cruz, CA
    95 M3
    Are you sure you didn't money shift?
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Quote Originally Posted by NoLastName View Post
    +1
    Project | 88M3 AW 43k miles OEM Shift Knob
    Auto-X | 99M3 Cosmos 60k S50B32 284į euro 6Spd 3.91
    Sat/Sun | 04M3 TiAg 65k non-sunroof 3 pedal
    Daily | 01X5 3.0 Schwarz 5spd manual
    Forum Rules
    New Member Info
    Aug 2017
    Staten Island
    I'm Honestly not sure I'm praying not but who knows at this point.
    From what I'm seeing it sounds better up around 1k but it just will not hold idle
    Aug 2017
    Staten Island
    If I did money shift would there be an oil or fluid leak of some sort or could the internals have just shit them selves?
    Jan 2002
    Central Pacific
    No one wants that.... a compression check will reveal if there is damage. A money shift doesn't necessarily spray parts all over. Bent valves is what will be the results. Any chance you downshifted and over-revved the engine?
    Forum Rules
    New Member Info
    Aug 2017
    Staten Island
    I know I hit redline but if I'm not mistaken I never made it into gear,
    Looks like it's time to go get a compression testing kit
    Jul 2011
    Austin, TX
    98 M3/4/5, '10 Escalade,
    Quote Originally Posted by SpartanX1 View Post
    They don't cost much, but you should be able to borrow one from any auto parts store.
    What you're describing sounds similar to what what happened to me - got misfires in adjacent cylinders (5 & 6), tried all kinds of things to diagnose, did a compression test and got no compression in either cylinder. When I took the head of, the gasket had just burned out between them.
    The good news is that it's not the end of the world - your head is likely still straight, and though tedious, the job isn't overly complex.
    Keep us posted.
    -Josh
    1998 M3/4/5 with most of the easy stuff and most of the hard stuff. 232k and running like a top.
    Aug 2011
    Charleston, SC
    95 E36 M3, 03 E39 540i6
    A HG job costs money. Put the car in storage, get a bike, fix car after graduation and a job. Racing around at 140 mph probably also not helping your studies. Are your parents aware of such activities?
    PCA HPDE Instructor
    1995 BMW M3
    2003 BMW 540i6 Alpine White M sport
    Aug 2017
    Staten Island
    They know I drive in a sporting fashion I don't believe they know to what extent though. After reading the post from yesterday I figured that I would be parking her for a while because well school has to come first right now. So i'm going to have to leave y'all hanging for a while but good news is once the summer internship starts and things loosen up, this project will really get going.
    Aug 2011
    Charleston, SC
    Donít forget to put some stabilizer in the fuel before parking it.
    I was in autocross club while in school, it was a fun distraction from engineering studies but I never had money to do it right. Although one learns how to be resourceful!
    PCA HPDE Instructor
    1995 BMW M3
  1. E36 (4) e36 M3 Wheels with like new Winter Tires
    By 2003e46zhp in forum Wheels and Tires
    Last Post: 03-20-2013, 11:42 PM
  2. E36 M3 Speakers sound like crap
    By angel8oyz in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 10-11-2012, 10:03 PM
  3. <FS> BMW E36 M3 Euro Headers - Like New - 325 328
    By rdorffer in forum BMW Parts For Sale (Panjo) sponsored by Bavarian Auto Recycling
    Last Post: 06-29-2003, 11:42 PM
  4. <FS> BMW E36 M3 OE Wheels Like New
    By rdorffer in forum Wheels and Tires
    Last Post: 06-15-2003, 07:00 PM
  5. Why does S54 M3's sound like shit with exhaust mods?
    By M powered in forum Z3 (E36/7, E36/8)
    Last Post: 06-09-2002, 03:43 AM
