Results 1 to 15 of 15
Thread: Letting the smoke out (pump)
    Jan 2012
    Upstate South Carolina
    1996 840Ci / 2007 B7
    Finally got my fuel pump out (after spilling quite a bit of gas all over the garage floor and top of the fuel tank). When I apply 12V to the pump contacts, the black wire terminal immediately starts smoking, looks like it's melting the insulation. No pumping sounds at all. I didn't try to switch polarity on the power source because I didn't want further damage - negative pole on the battery was sending to the black wire. Is the pump completely toast? Salvageable with some seafoam? I'm just testing it wrong?
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    I can't help you with the wiring but if you are using the right polarity and pump is not running then its probably seized. Seems like it would run either direction if current is reversed or not. I would probably buy a can or two of Seafoam at wallyworld, pull off filter, and let pump stand in fluid for several days and see if it frees up.
    And, pump should not be run 'dry' from what others have mentioned on here.
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Pump is dead. I have a new one left over, sent you a PM.
    Sunny Cali,
    6.5 second 69 Camaro
    I just gained more appreciation for LHM,) Your carrier looks to be in good shape.
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    1. Do NOT run the pump when it isn't submerged in gas. NO NO NO. Never.
    2. Replace pump. (see #1)
    3. If that pump ever was any good, it most assuredly isn't now... hence the smoke.
    4. Replace pump. (see #1)
    5. Did I mention not to dry run the pump? Not Ever.
    '91 850i 6sp (mint) (sold)
    Jan 2012
    Anything special for a wire submerged in gasoline? Or can I just use regular wire that I already have for other purposes?
    What's LHM, 8eights?
    Also, what is so special about this pump that even a second or two of dry running would be so detrimental. I think it was dead already, and was trying to test to see if it even spun... What happens if you run out of gas? Won't the pump continue to run dry at that point?
    Quote Originally Posted by CDO5OO1A View Post
    <-- What he said. AND wire will NEED to be re-terminated and the end of the wire that got hot cut off. Once copper gets that hot it loses a percentage of its conductive properties.
    At least the first inch looks toasted.
    The filter at the bottom looks like it might be split too.
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by Spandrel View Post
    You can use regular wire. Running a pump dry usually damages the pump or shortens it's life span.
    Sep 2008
    Santa Barbara
    I'd use a couple of layers of quality heatshrink to rehab the oem wire if it were me. Way better than a splice. Hot or not, that wire is more than healthy enough to run the pump
    When you run out of gas, there is still enough gas in the pump for lubrication, it won't spit it all up the tube when it stops coming in. No dry pump runs, please
    LHM = Limp Home Mode, or running on 6 cylinders by design
    Sunny Cali,
    As Cartoonz mentioned, The ability to drive the car with a dead fuel pump because 2 pumps are available, 1 per each bank for V12's So you can still crawl to safety and further with half a engine.
    Jan 2012
    Thanks, Ed. New one is not an exact replacement as it doesn't have the retainment ridge below the top to secure it in the carrier - zip ties will suffice, I hope. Made a guess at polarity that the larger screw was negative in the same way the larger screw on the original unit was negative. Also had to repair one of the rubber dampers (zip tie again - through both remaining rubber parts to maintain function). Ended up splicing the negaitive wire that was smoking using an inline splice, solder and some heat shrink tubing. Looks ok. About to install and find out if it works.
    Quote Originally Posted by dragon850 View Post
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Well, did it fire up? That install should be good enough..
    Jan 2012
    It did!!!! Three and a half years in the middle of my garage and it moves under its own power!
    (No power steering, battery light and trans fail safe (still needs fluid after 8 liters in. Don't understand that one), but I'll take the progress!)
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Nice!! Good to hear!
    Sent from my SM-G892U using Tapatalk
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    About time too!
    My BMW Repair YouTube Channel
    Orlando, FL USA
    Congrats on the progress...we all know the feeling too well. As Timm would say, "time for a cup of tea".
  1. Engine idle rpm rises when I let the clutch out. Anti-Stall System?!?
    By shanecconn in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 09-28-2017, 03:29 PM
  2. Clink and thud when letting the clutch out
    By OutAndBack in forum 1988 - 1996 (E34)
    Last Post: 03-01-2013, 05:40 AM
  3. Replies: 2
    Last Post: 02-13-2008, 02:28 AM
  4. So im hearing a slight rattle behind me when I let the clutch out...?
    By Zaf///Mroadster in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-07-2007, 10:30 PM
  5. Letting the cat out of the bag
    By 2000Z3M in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-22-2007, 08:26 AM
