Results 1 to 25 of 41
Thread: Anyone doing a R134a conversion for summer? Let's pool knowledge...
    Jul 2013
    CT
    1989 325i 4 Door 5sp
    Hi all
    I want real A/C this summer. I've been poking around some threads, several of which are a bit older at this point and figured I'd start one to pool knowledge.
    This thread comes up often on searches: https://www.r3vlimited.com/board/sho...d.php?t=246743
    Does anyone have a current shopping list or experience to share?
    Mine is an '89 325i Sedan which the previous owner "converted" to R134a by changing the port and flushing. It doesn't hold a charge. Compressor is leaking some (did a UV dye test). Time to do it right.
    Sep 2014
    KS
    e24e30e36e39e90
    I haven't done it yet, but I've done extensive research, here's my raw notes dump. There is a mix here of new stuff, as well as some compressor repair/rebuild info. My plan is to buy everything from rockauto.
    http://www.r3vlimited.com/board/showthread.php?t=246743
    Rock Auto Parts
    Compressor, dryer and pressure switch
    $265
    http://www.rockauto.com/en/moreinfo....011700&jsn=387
    Condensor
    $106
    http://www.rockauto.com/en/moreinfo....sn=381&jsn=381
    FOUR SEASONS 59976 R
    -12 TO R-134a RETROFIT KITS AND FITTINGS - LOW SIDE
    FOUR SEASONS 59978
    R-12 TO R-134a RETROFIT KITS AND FITTINGS - HI SIDE
    FOUR SEASONS 26773 AC System Seal Kit
    FOUR SEASONS TSR0911 Tech Select A/C Kit Reman
    http://www.compressor-intl.com/index.html
    http://www.thecompressorwarehouse.com/results.cfm
    http://www.techchoiceparts.com/inventory
    https://www.youtube.com/watch?v=MangGmPZc6g
    https://www.youtube.com/watch?v=Zn9N5sypuME
    https://www.youtube.com/watch?v=sh-KIjAqh-A
    pull vacuum before replacing all o rings
    flush system
    compressor repair parts
    http://max-ac.com/10P15E_c_22506.html
    The compressor gasket set contains mostly o-rings: 1) three large o-rings for resealing the case sections, 2) four small o-rings for resealing the suction and discharge fittings - where the shraeder (sp?) valves are located (you know, like the valves on a bicycle tire/inner tube), 3) one small o-ring for the shaft seal seat (a duplicate for the one in the shaft seal kit), and 4) five washers to use with the head bolts (again, duplicates for the ones in the shaft seal kit).
    compressor diagram
    http://www.acsource.com/10p13c10p15c...breakdown.aspx
    repair diy
    http://www.pelicanparts.com/techarti...so_rebuild.htm
    http://members.rennlist.com/elsies91...nsorebuild.htm
    system picture
    http://s115.photobucket.com/user/bea...nes-1.jpg.html
    refrigerant
    http://www.harborfreight.com/18-oz-a...uge-97275.html
    http://www.realoem.com/bmw/enUS/part...BMW-325i&mg=64
    64521386256
    10P15E
    Denso
    o rings
    http://www.r3vlimited.com/board/show...5&postcount=11
    oil viscosity
    https://docs.google.com/file/d/0B6qM...t?pref=2&pli=1
    http://www.rockauto.com/en/moreinfo....011700&jsn=368
    http://www.techchoiceparts.com/inven...-ac-compressor
    http://www.e30tech.com/forum/showthread.php?t=113435
    http://www.exx.se/techinfo/docs/r134a_retrofit.pdf
    http://www.compressorsoftheworld.com...ompressors.php
    NipponDenso 10p15e compressor $30
    Vapor hose from firewall to compressor w/ 5/8" tube fitting $10
    Buy the following new:
    Receiver-drier $20
    O-rings all around $3
    R134a expansion valve $20
    Compressor-to-condenser barrier hose $30
    Drain the oil from the compressor and rinse with mineral spirits.
    If you have an air compressor, flush some mineral spirits or other evaporating cleaner through each hose individually.
    Aug 2011
    Wake Forest
    2004 525i, 1985 325E
    I plan on taking this on next month. I have a lot of the parts. I had a local shop covert all the rubber hoses to R134 compliant. I have cleaned all the hoses but will do it one more time before installation. I'm still deciding on the compressor. Then I need to source a vacuum pump and charge hoses. Not sure if I want to buy or borrow (I like my own tools). But not knowing if I'll ever use them again has me reconsidering.
    2004 525i Sport, Manual - 1985 325E Coupe Manual
    Feb 2018
    Anderson SC
    2000 BMW 528i
    Quote Originally Posted by tomstin View Post
    Can you post up some helpful tips on this thread when you are done, such as any special tools or anything to watch for as you complete yours?
    I am subscribed to this thread because this is something that I think I may want to do soon as well.
    Sent from my SM-N920P using Tapatalk
    Jul 2013
    CT
    When you say 'convert' the hoses what does this mean - recreate or...?
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    You can get a vacuum pump kit with hoses and gages on ebay for around 100 or 130 bucks. I bought one last summer and its worth having. I used alcohol to clean the system on my son's 86 and we opened the compressor, just to clean it, and it was full of little rock looking chunks. We cleaned it out with alcohol, also, and assembled the whole system back onto the car, vacuumed and filled it, and now the ac blows at 54. Its freaking cold and i turn it to low when i drive because its so cold.
    It was not hard at all. Just time consuming to clean everything, and the vacuuming takes time
    Jul 2013
    CT
    Does anybody know which new compressor is a direct replacement for my nippondenso 10P15E? I suppose I could rebuilt it (it leaks per UV test) but starting with a new, r134 compatible unit seems worth it.
    Dec 2005
    No e30s, again :(
    I don't know. I need to find out because my other son's car has a dead compressor. we took it apart and its not coming back so I need another one.
    No e30s again.
    Jul 2013
    CT
    Getting started on this and ordered condenser, dryer, switch and expansion valve, hopefully all correct to R134a - they are to the best of my knowledge.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Griffiths says there are two types of nose seals on my Nippondenso so I'll pull and dismantle before ordering the rebuild kit.
    https://griffiths.com/product/porsch...0p15-seal-kit/
    Sep 2014
    KS
    e24e30e36e39e90
    There are three youtube links in my first post in this thread, they cover replacing seals, bearings and clutch on a Denso compressor, not a 10P15E but close enough to be helpful.
    Jul 2013
    CT
    I watched them and they are sweet relief from all the "whats up youtube" dudes taking the scenic route. I'll buy parts from him as a thank-you.
    Jul 2013
    CT
    Dec 2005
    No e30s, again :(
    Cool
    No e30s again.
    Jul 2013
    CT
    Does anybody have a tip about removing the outer plate of the clutch? The 12 mm bolt is off but it does not want to budge. From what I read a gear puller or similar is not supposed to be required
    Dec 2005
    No e30s, again :(
    not here. I have not had to go that far, yet
    No e30s again.
    Jul 2013
    CT
    Using chisels as wedges broke it loose, it was evidently seized on the shaft.
    Still needed a puller once I could work the arms around the back of the plate.
    Rest is easy, remove circlip, remove coil, remove circlip, remove nose piece.
    Jul 2013
    CT
    more
    Jul 2013
    CT
    The reason why there are so many problems with belt tension. Replacement part surprisingly reasonable.
    Apr 2014
    DFW TX USA
    1983 320I, 1986 325E
    This hasn't been mentioned yet. You should use ester oil. PAG oil becomes corrosive once it contacts residual mineral oil from when the system ran R12. Ester oil does not do this and is compatible with nearly all other oils and refrigerants. I am running hc12 in my e21 and get vent temps around 45-48 Fahrenheit when moving. The only changes I made to the system were a e30 rotary compressor and new o rings.
    Jul 2013
    CT
    Thanks for bringing this up. I did some reading and concur - and was able to intercept my recent compressor parts / o ring / oil order in time to change it. FYI I bought from these guys who have been very helpful.
    https://www.google.com/url?hl=en&q=h...Dsd0jtvm-MGSBw
    Dec 2005
    No e30s, again :(
    good info
    No e30s again.
    Jul 2013
    CT
    Starting to question if I did some damage to the clutch plate when prying it off. I realize now there is a dedicated tool for this job and that the plate has outer threads. To my knowledge the plate is not available as a replacement part. Has anyone had good experiences with an ebay or Four Seasons remanufactured Denso 10p15E?
    Dec 2005
    No e30s, again :(
    I have not tried them
    No e30s again.
    Jul 2013
    CT
    New receiver dryer is confusing me a bit. It was sold along with the new high pressure switch, but has no threading to accept the high pressure switch as the original unit did. I understand the low pressure switch can be omitted but I'm confused by the the high pressure issue.
    Jul 2013
    CT
    doh! the HP switch threads onto the Schrader valve. Okay carrying on...
    This vid explains it: https://www.youtube.com/watch?v=nQi3mI9_aEU
  1. Replies: 2
    Last Post: 09-29-2007, 04:58 PM
  2. Anyone doing the OC thing this summer..
    By NYQUEENZ in forum Middle Atlantic - US
    Last Post: 03-31-2004, 08:02 PM
  3. anyone do the bixenon conversion and remove the lens?(willy?)
    By mrclam in forum 1992 - 1999 M3 (E36)
    Last Post: 08-20-2003, 11:10 PM
