I am looking for advice....
I just had the lights and strip replaced in my 2005 X5 interment cluster and installed it... All the gauges work, but everything else is not working... Turn signals, LED bar, service lite etc...
Is there something that I need to do to reset this? I have tried to pull the #1, #43 & #45 fuse for a reset as advised by another person,,, but no luck...
Thanks in advance
Scott
Have you removed the cluster to double check if ALL the connectors are hooked on correctly? Sometimes we can miss simple things or think that we put the connectors back on correctly (but didn't).
Yes I checked every connection, still no luck.
Update: I removed the wires from the locking retainer housing and connected it directly and tested it.... Everything works now. I just need to find a replacement clip from a junk yard and swap it out.
Thanks for input ..
