Results 1 to 7 of 7
Thread: Where do I start?
    Mar 2018
    Montgomery, Alabama
    1985 325i Sedan
    Where do I start?
    Super low miles, runs great, don’t know where to start. My first BMW, 1989 sedan, only 75K miles.
    Mar 2012
    Hopewell Junction, NY
    1987 325iS...edan
    Start at the FAQ/DIY section of this forum:
    https://www.r3vlimited.com/board/forumdisplay.php?f=107
    Mar 2018
    Montgomery, Alabama
    1985 325i Sedan
    Ok thanks
    Jan 2016
    Ca
    2001 525it
    Timing belt is the most important thing about this car
    323i E30's Avatar
    323i E30 is offline ⅂!ʈө !ƨ l!ʞө ɐ ʇөlөbµouө
    Jan 2013
    Europe
    M52 E30 touring & E91
    Quote Originally Posted by jclausen View Post
    +1
    Check when it has been replaced for the last time. That thing needs refreshed every 5 years (or 60k miles).
    Maintenance records, or otherwise often a sticker on the fuse box or strut tower should tell.
    If it's worn and it snaps, your engine will suffer serious damage.
    ^ true story
    D̶i̶b̶s̶ ̶o̶n̶ ̶t̶h̶e̶ ̶E̶2̶1̶
    Mar 2018
    Montgomery, Alabama
    1985 325i Sedan
    Aug 2011
    Wake Forest
    2004 525i, 1985 325E
    Get the Bentley manual. https://www.amazon.com/BMW-E30-Servi...mw+e30+bentley
    As mentioned, timing belt is critical. While you're there, water pump, flush the block and radiator, replace the hoses, I prefer BMW coolant.
    Next, check the fuel in the gas tank, depending on how long it was sitting and the type of gas, you may have a lot of junk in the tank. Replace the fuel filter.
    Vacuum leaks while running will probably be your next challenge. The intake boot and vacuum hoses need to be inspected and replaced as necessary. Inconsistent idle is a know challenge...search. A lot of good information out there. No silver bullet, every instance is a bit different.
    Assume after this you have it running. Not make sure it can stop. Check the brakes, flush the fluid.
    Inspect the suspension. Make sure nothing is falling apart. Shocks, struts, ball joints, and all the rubber bushings related to the suspension need to be evaluate.
    I hope you can do a lot of this yourself or have some knowledgeable help. These car can be very expensive to maintain if you can't do it yourself.
    Every piece of rubber on these cars is roughly 30 years old so you can expect to need to replace a lot of it over the next several months.
    A few sources of parts that have been very good to me:
    https://www.pelicanparts.com/BMW/index-SC.htm
    https://www.getbmwparts.com/
    Of course there are others, and you will find what works for you.
    2004 525i Sport, Manual - 1985 325E Coupe Manual
  1. New BMW driver here.... where do i start????
    By momatt82 in forum 1983 - 1991 (E30)
    Last Post: 04-14-2005, 01:39 PM
  2. Help: Where do I start?
    By JoeIsu325 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-27-2004, 02:12 AM
  3. Where do I start looking for an E46 Engine
    By E46325Ci in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-22-2004, 02:16 PM
  4. Where do I start? My paint job is dull
    By RacermeX in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 08-20-2003, 09:50 AM
