Results 1 to 9 of 9
Thread: Widebody M3s- favorite shots
    West Chester PA
    Widebody 95 & 97 M3s
    Cool Widebody M3s- favorite shots
    Haven't posted on here in some time, put these shots together of each car from over the years (have had them for 15 years and 8 years respectively). I know some will probably like some things, others wont, no big deal. Keep an eye out in PBMW this summer for each car.
    The yellow car is currently at the bodyshop for a GTS hood, authentic Pandem spoiler, canards, black painted moldings and roof, some new retrofit headlights, and non-bubbling door panels. The silver car is hibernating, nothing new to report other than maintenance for the most part...
    Full Respray in Aston Martin Ligthning Silver Pearl Paint
    Esquiss Widebody Front Fenders & Rear Quarters
    Esquiss Gas Door & Extension
    Custom Carbon Fiber AC Schnitzer Deck Spoiler
    Custom Widened OEM ///M3 Front Bumper With Custom Moldings, Molded Fogs and Molded Vorsteiner GTS3 Spoiler
    Custom Widened Rieger Infinity I Rear Bumper
    Custom Made Carbon Fiber Rieger Rear Diffuser
    JTD Underpanel
    Erebuni Carbon Fiber Vented Hood
    VIS Carbon Fiber Trunklid
    Carbon Fiber AC Schnitzer Sport Mirrors
    Carbon Fiber Zeemax Roof Spoiler
    Carbon Fiber Sunroof Panel
    Widened Rieger Infinity II Widebody Sideskirts
    Carbon Creations Carbon Fiber Sideskirt Splitters
    Carbon Fiber Kidney Grills
    VIS Carbon Fiber License Plate Trim
    Carbon Fiber Eyelids
    Satin Black Powdercoated Lower Grill Racemesh
    Full Carbon Fiber Hood & Trunk Emblems
    19x9 DPE SP-10 et26 Reverse Chrome Lip & Matte Black Face/Inner Barrells (Front)
    19x11 DPE SP-10 et16 Reverse Chrome Lip & Matte Black Face/Inner Barrels (Rear)
    255/30/19 front and 305/25/19 rear Toyo T1R's
    Bosch Headlights
    Custom Carbon Fiber Headlight Lenses
    Orion V2 Angel Eyes
    6000k Prolumen HID’s In Low Beams
    OEM Euro ///M3 Clear Corners
    Stealth Bulbs
    Bimmian LED License Plate Lights
    RMS Stage 3 Supercharger Kit
    Polished Vortech V-2 Si Trim Supercharger
    6” 8 Rib Crank Pulley
    3.15” 8 Rib Supercharger Pulley
    RMS Aluminum Idler Pulley
    Schrick Camshafts (256/264)
    AA Tuning Custom Software
    ARP2000 Head Studs
    M50 Intake Manifold
    Eric’s M50 Manifold Conversion Kit
    Stratmophere Hyperboost HX Compact BPV
    Porsche 993TT 3.5” HFM
    42LB Injectors
    Zionsville Radiator With Oil Cooler Provision
    Mishimoto Expantion Tank
    Hard Motorsports Oil Pan Baffle
    Custom RMS Aluminum Heat Exchanger
    CES Cutring Head Gasket
    Dr. Vanos Stage 2
    IWIS Racing Timing Chains
    Samco Radiator Hoses
    Euro ///M3 Oil Filter Housing and -10AN Fittings
    Euro ///M3 Oil Cooler
    Dinan Big Bore Throttle Body
    RMS Headers
    Supersprint Euro Midpipe
    Supersprint Euro Cat-Back
    Kenne Bell Boost-A-Pump
    Carbon Fiber Oil Catch Can
    Aquamist 1s Water/Methanol Injection Kit
    UUC Underdrive Pulleys
    Ground Control Green Gizmo
    UUC Oil Center
    Engine Aesthetics:
    Dinan Carbon Fiber Radiator Cover
    Dinan Carbon Fiber Engine & Fuel Rail Covers
    Dinan Carbon Fiber Alternator Duct
    Custom Powdercoated Red & Black Chrome Supercharger Bracket & Bolts
    Black Chrome Powdercoated Hood Latches & AC Condenser Bolts
    Mirage Battery Cap Connection Cover
    Mirage Stainless Windshield Washer Fluid Tank Cover
    Mirage Stainless Windshield Washer Fluid Cap Cover
    Mirage Stainless Brake Fluid Reservoir Cover
    Carbon Fiber Fuse Box Lid
    Carbon Fiber ECU Cover
    Gloss Black Brake Fluid Reservoir
    Billet Radiator Latches
    ECS Polished Dip Stick
    Billetwerks Oil Cap
    Billetwerks Diagnostic Cap
    Billetwerks Brake Fluid Reservoir Cap
    Polished Engine Latch Hook
    E46 ///M3 6 Speed Transmission
    Diffs Online 3.46 Differential With 40% Lockup
    Rogue Engineering Finned Differential Cover
    UUC Stage 2 Flywheel
    UUC Segmented Kevlar Clutch
    UUC Euro ///M3 Evo III SSK
    Active Autowerke Differential Support Bracket
    UUC TME Kit
    UUC SS Clutch Line
    UUC Clutch Arm Bushings
    UUC Delvin Carrier Bushings
    UUC Clutch Stop
    Z3 Steering Rack
    H&R Coilovers
    UUC Sway Bars
    OEM X-Brace
    Bimmerworld Motor Mounts
    VMC Sway Bar End Links
    CFWerks Carbon Fiber Front Strut Bar
    SPC Rear Control Arms
    Rotora Front 6 Piston 355x32mm (14") Big Brake Kit
    Rotora Rear 4 piston 330x30mm (13") Big Brake Kit
    Rotora Stainless Steel Brake Lines
    Turner Motorsport Carbon Fiber Brake Ducts
    Leather Sparco Milano Seats With Sparco Brackets And Sliders
    Custom Carbon Fiber Raid SILBERPFEIL TYP 2 320mm Steering Wheel
    OEM Euro ///M3 Power Rear Vent Windows
    OEM BMW Motorsport Red Front And Rear Seatbelts
    Powdercoated Arctic Silver Autopower Street Roll Bar
    Carbon Fiber Dash
    Whalen Hood Release Lever
    Carbon Fiber Steering Wheel Cowl
    Carbon Fiber Passenger Side Airbag Cover
    LeatherZ Armrest Cover
    Carbon Fiber Glovebox Door
    Carbon Fiber Interior Mirror Covers
    Carbon Fiber Door Latch Surrounds
    Custom Made Carbon Fiber Center Console Screen Panel
    Carbon Fiber Autometer Gauge Pods On Steering Wheel Cowl & A-Pillar
    Carbon Fiber Lower Seatbelt Bolt Covers
    Carbon Fiber Upper Seatbelt Bolt Covers
    Custom Made Carbon Fiber On Board Computer Compartment
    Carbon Fiber Inner Door Sills
    Carbon Fiber Rearview Mirror Control
    Carbon Fiber Rear Seatbelt Surrounds
    Carbon Fiber Dimmer Switch Panel
    Carbon Fiber Rear Center Console
    Carbon Fiber Armrest Separator
    Carbon Fiber Vanity Lights
    Carbon Fiber Headlight Knob
    Carbon Fiber Headliner Handles
    Carbon Fiber Door Pulls
    Carbon Fiber Nitrous Express Bottle
    Custom Suede With Red Stitching Bottle Holder
    PLX DM-5 SM-AFR Gauge
    Autometer ES Boost Gauge
    VDO Oil Pressure Gauge
    VDO Oil Temperature Gauge
    VDO Voltmeter Gauge
    VDO Water Temperature Gauge
    Custom Suede/Fiberglass Drivers Side A-Pillar With Three Molded In Gauge Pods
    Suede Headliner, A, B, and C Pillars
    LeatherZ Suede With Grey Stitching E-Brake Boot
    LeatherZ Suede With Grey Stitching Shift Boot
    OEM Z3 Oval Rear-View Mirror Wrapped In Carbon Fiber
    OEM Z8 Push Start Button (In Place Of Cigarette Lighter)
    OEM E39 ///M5 Mood Lights Retrofitted in E36 Blacked Out Housing
    Valentine 1 (Hardwired)
    Custom Illuminated Chrome & Brushed ///M3 Side Sills
    Active Autowerke Shift & E-Brake Handles
    OEM Extended Leather Package Stitched Panels
    AC Schnitzer Polished Door Lock Pins & Surrounds
    Polished Shift Boot Surround
    9-LED Interior Lights
    AC Schnitzer Pedals
    AC Schnitzer Floormats
    AC Schnitzer Carbon Fiber Gauge Overlay
    Polished Gauge Bezel Rings
    Custom Paint Matched Fiberglass Rear Parcel Shelf With Bass Port With LED Third Brakelight
    Paint Matched Center Console
    Paint Matched Door Handle Pulls
    Paint Matched Rear Ashtray
    Paint Matched Glovebox Trim
    Pioneer DVH-P5000MP DVD Player Head Unit
    7" Lilliput EBY701 Touch Screen in OBC/Sunglass Holder Area
    Custom Suede Trunk Screen Panel With MB Quart Components, Diamong Plating, And LCD Screen
    Custom Suede Sun Visors With 5" Power Acoustik T5009msv Screens
    On Board Computer Moved To Cupholders
    Custom Ported Sub Box With Glass & Mirror Covering
    LED Sub Box Lighting
    Custom Suede Trunk Paneling
    2 10” Kicker Solo-Baric L7 Subwoofers
    Kicker KX 850.2 Amp
    Audio Precision PC450 Amp
    MB Quart QM 130 Rear Speakers
    Vifa NE65W-04 2" Mid Range Speakers
    Whelen Strobe Light Kit
    Jensen Video Amplifier
    CAE Power Inverter And HP4 Cord
    Viper Keyless Alarm System
    Full respray in Ferarri Giallo Triplo Strato
    Zeemax Widebody Front Fenders and Rear Quarter Panels (molded)
    Zeemax Widebody Sideskirts
    Widened OEM Front and rear bumpers
    Molded AC Schnitzer Carbon Front Lip
    Custom Carbon Fiber Splitter
    FancyWide Diffuser
    AC Schnizter Type 1 Carbon Mirrors
    Carbon Fiber Trunk Trim
    Carbon Fiber Canards
    Carbon sideskirt splitters
    Shaved Sidemarkers & rear quarter lines
    Smoothed fog deletes & brake ducts
    Carbon Fiber Hood & Trunk Badges
    Depo headlights with FXR 3.0 Projectors, City Lights, 50W Phillips D2S 6000k HIDs & Dual Highs & Custom ///M Stripes
    Rocket Bunny Pandem Trunk Spoiler with Black Hardware
    Jet Black Painted Moldings & diffuser
    Jet Black Painted Roof
    Jet Black Kidney Grills
    DTM Fiberwerkz GT-S Hood with Carbon Vents
    OZ Mito 3 Piece Type 1 18x11.25 et15 rear with 3.75” lips and 255/35/18 tires, 18x9" ET27.5
    AC Schnitzer Roof spoiler
    OEM clear rear tail lights
    Smoked front corner lights
    Motion motorsport underpanel
    LED Licence plate lights
    Stealth Bulbs
    DTP Trunk Reinforcement Plate
    Schrick Cams
    Super Sprint headers
    Super Sprint Catback exhaust
    RC Engineering 69mm Big Bore Throttle Body
    Mishimoto Radiator Hoses
    Mishimoto Polished Expansion Tank
    Edelbrock Heat Exchanger
    6” Crank pulley
    3.33” Supercharger pulley
    42lb Injectors
    3.5” Porsche 803 MAF
    ARP Head Studs
    CSF Radiator
    OEM Euro M3 Oil Cooler
    Simota oil catch can
    VAC Oil Filter Housing Cap
    Magnetic oil drain plug
    Aquamist 1s Water/Alcohol injection
    Stewart water pump
    Kenne bell boost-a-pump
    OEM S54 Oil Filter Housing
    Turner Motorsport Oil Cooler & Housing -10AN Fittings
    Turner Motorsport Underdrive Pulleys
    JE Cut Ring Head Gasket .079”
    Supersprint midpipe
    RMS Metal Idler Pulley
    AA Custom Chip
    VAC Oil Pan Baffle
    Engine Aesthetics
    Euro Carbon Radiator Cover
    Powdercoated OBD1 Valve Cover, Aftercooler, & Supercharger Brackets
    Mirage Polished Battery Cap Cover
    Mirage Polished Fuse Box Cover
    Mirage Polished Brake Reservoir Cover
    Mirage Polished Washer Tank Reservoir
    Mirage Polished Washer Fluid Cap
    Mirage Polished Brake Fluid Cap
    ECS Tuning Polished Dip Stick
    Colored ///M Power Engine Cover and Fuel Rail Cover
    Billetwerks Oil Cap
    Re-upholstered OEM Vader Seats & Luxury panels
    Raid Silberpfeil typ 1 320mm airbag steering wheel
    OEM BMW Motorsport Red Front & Rear Seat Belts
    Storm Motorwerks Lighter Plug
    Suede headliner, A and C pillars
    AA Shift & E-Brake Handles
    OEM MZ3 Rearview Mirror
    LED interior lights
    Brushed aluminum pedals
    AC Schnitzer Floor Mats
    Rallyroad Steering Wheel Gauge Pods
    Innovate Boost Gauge
    Polished Door Lock Surrounds
    Polished Shift Gaiter
    Innovate AFR Gauge
    E39 OEM Mood lights for overhead dome light
    VDO Water Temperature Gauge and Sender
    VDO Oil Temperature Gauge and Sender
    VDO Oil Pressure Gauge and Sender
    LeatherZ Gauge Panel
    Custom Battery Cover with fire extinguisher
    OEM Euro ///M3 Evo Power Rear Vents
    Black trunk carpeting & paneling
    Black luxury door pulls
    Carbon Door Lock Pins
    Carbon door latch surrounds
    Carbon Fiber Inner Mirror Covers
    Polished window/sunroof switch surrounds
    Carbon fiber Gauge Surround
    Polished Gauge Rings
    Suede rear deck panel with custom speaker openings
    OEM Motorsport Carbon Door Sills
    Carbon Fiber Glovebox Trim
    Carbon Fiber Dash
    JVC KD-NX5000 Head Unit
    Vifa NE65W-04 Mid Range Speakers In HK Housings
    BSW Tweeters
    Infinity Kappa Footwell Speakers
    JL Stealth Boxes
    Kicker 40 CWS84 8” Subs
    Helix B4 Amplifier
    Kicker 40CS54 Rear Midwoofers
    Kenwood Excelon X501-1 Amplifier
    OEM E46 M3 6 Speed transmission swap
    3.38 Rear Differential
    Z3 steering rack
    UUC Clutch Stop
    UUC Black Transmission Mounts
    UUC Stainless Steel Clutch Line
    Rallyroad stainless steel clutch pivot pin
    UUC Engine Mounts
    Top Speed Pro1 Performance Short Shift Kit
    H&R Coilovers
    UUC sway bars
    Turner motor sports rear camber arms
    BavAuto Front Strut Tower Bar
    Dinan Rear Strut Tower Bar
    OEM X-brace
    RallyRoad Porsche 996 Brembo Front & Rear Big Brake Kit
    Rigel 7
    99 M3, 850i
    Holy. This is the kind of thread that in 2005 would require a "56K...go make a sandwich" type of title.
    Both cars are exemplary of their styles, as always. Loving the yellow one especially with that classic boxed-fender widebody.
    Mar 2011
    Bellevue, WA
    Crazy you have two of these! Both cars are great, can’t wait to see the yellow one after the next round of work!
    Dec 2008
    Philadelphia ,Pa
    2015 X1 & 2000 M5
    Love them both as usual! Shame I couldn't make FCF this past year, should be back this year though with the M5 on the mitos.
    Del a Where?
    LSx M3 & 2014 Touareg
    Pic overload! I love it hahah
    They're looking sick as always. Maybe once this weather gets better we finally do a shoot
    Wadsworth, Ohio
    Stop it! Now I want another E36! Both cars look fantastic!
    Have questions? Need answers? Live Chat us! 8:30am to 12:00am Midnight EST
    Customer Service Hours: M- F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
    Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
    Facebook | YouTube | OEM BMW Part Number Search
    Feb 2016
    Rogers AR
    1995 BMW M3
    They look amazing!! I enjoyed scrolling through all those pictures
    Aug 2008
    06 MR
    Not sure who would say anything bad about either car especially from a og.. Have loved both for a long time.. Wasnt the yellow one built for your dad? iirc
    I dig them both. I've always liked the silver one, I love the Esquiss kit and all the little details throughout the car.
    The yellow one is going to look dope with the new hood and spoiler.
    -Varis-Hartge-Seibon-Umnitza-TRM--Mason Engineering-Zionsville-Mishimoto-Stewart-Conforti-BMW ///M/LTW
  1. Anyone have a widebody m3?
    By m3j0n in forum 1992 - 1999 M3 (E36)
    Last Post: 03-14-2003, 06:32 PM
  2. What's The Verdict On Widebody M3's?
    By Ron17 in forum Off-Topic
    Last Post: 01-24-2003, 07:22 PM
  3. widebody m3 coming... need help
    By M3sRsick in forum 1992 - 1999 M3 (E36)
    Last Post: 01-17-2003, 06:58 PM
  4. Widebody M3 on eBay
    By ibizam3 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-09-2003, 02:09 AM
  5. Widebody M3
    By LouisM in forum 1992 - 1999 M3 (E36)
    Last Post: 01-03-2003, 03:23 PM
