Results 1 to 7 of 7
Thread: E39 rims
    Mar 2018
    Tacoma
    Honda prelude
    E39 rims
    Will these rims fit my 2003 530i?
    Size 17x8
    Offset et10
    Bolt patter 5x12
    (Sorry I'm a scrub)
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E39 forum
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    BMW wheels are "hub centric" not "lug centric"...so the center bore of the wheel is an important spec to know. If the center bore of the wheel is NOT 74.1mm...then you'll need to know if the wheels center bore is larger or smaller than 74.1mm.
    You can see the wheel hub of a BMW in the pic below...BMW wheels mount on the small circular extension on the wheel hub and that's what centers the wheel (not the lug bolts):
    If the wheel's CB is larger than 74.1mm...then you'll need to fit hub centric rings (to help "fill" the circumference) or purchase wheel spacers that fixes the different hub sizes. If you don't then the wheels will probably not stay centered and you'll get vibration. Even if you do center them...if you hit a bump/hole/heaved pavement/etc...it could shift the wheel if the hit was hard enough since the wheel is sitting flat against the hub with nothing to center it (because the set-up is NOT lug-centric).
    If the wheel's CB is smaller than 74.1mm...then you'll need to either bore the wheel out to the correct size...or purchase wheel spacers that again...fixes the difference.
    San Jose, CA
    1997 BMW 540i 6 speed
    Did the wheels come from an E39?
    Jun 2013
    Lancashire - UK
    2002 BMW E39 530i (UK)
    Quote Originally Posted by Patrickvn253 View Post
    Size 17x8
    Offset et10
    Bolt patter 5x12
    (Sorry I'm a scrub)
    No, BMW are 5x120
    You'd either need to use specific adapters, or get them drilled out
    ET10 is probably ok, if lowered you'd risk rubbing but if OEM suspension, should be ok
    BMW E39s centre bore is 74.1 as well, so the alloy wheel bore needs to be this, or larger and then you can use spigot rings
    If smaller, you'd need 74.1 to 72.6 hubcentric spacers to allow the alloys to fit, longer bolts will be needed then also, or you can do a stud conversion
    Either way, without work, those alloys will not fit
    My car: 2002 E39 540i Sport - Japanese import - the new project!
    (northeast) Indiana
    Size 17x8
    Offset et10
    Bolt patter 5x12
    (Sorry I'm a scrub)
    Hmmm...I probably shouldn't have assumed that the "bolt pattern" was a typo...oops.
    Jun 2013
    Lancashire - UK
    Quote Originally Posted by Qsilver7 View Post
    Ah, maybe my fault
    I misread and saw it as 5x112...
    The OPs probably asking re 5x120, which will fit obviously, but if they're 72.6 CB then they'll need boring out, or he does the E60 hub conversion!
  1. E39 E39 rims with Michelin tires Style 82
    By germster in forum Wheels and Tires
    Last Post: 04-24-2013, 11:06 AM
  2. E39 BMW M5 e39 Rims Style 65 Refinished 18's
    By Photopark in forum Wheels and Tires
    Last Post: 06-15-2011, 01:17 PM
  3. E39 Wtb any e39 rims
    By KnnyDz in forum Wheels and Tires
    Last Post: 08-10-2010, 08:01 PM
  4. E39 Hub centric rings for e34 to e39 rims
    By miroxz in forum Whole Parts Cars
    Last Post: 08-10-2007, 01:50 AM
  5. E28 535 w/ E39 rims
    By nftyM3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-12-2002, 06:28 PM
