I need to replace rear tires on M Parallels. I am looking at 275/45 as I want a little more side wall. I know this will cause a height mismatch between front and rear. What I am curious about is what systems will this cause to go haywire? Will the dash light up like a Christmas tree? Will the traction control kick in when it's not suppose to kick in?
If this will cause issues can I compensate by putting 245/50s in the front to match front and rear height or will the car know that the overall height is different than stock?
1991 318is
2001 740i
I know the traction control will sense the difference, and so will the transmission, since it uses the speed sensors. Best bet is 275/40. The speed sensors measure speed related to each wheel, so going bigger all around will be OK if you keep the rolling diameters within 3% of each other. Once you get outside of that its game on. You should do some more research on this, maybe Q has the real technical answer for you.
I think I was running 245/45 and 275/45 and had no problems. I will have to check the rears. The 275/45s are about 1.4% bigger than stock whereas the 275/40s are 2.6% less. Whatever sizes I have, I was happiest with this setup. The new one has 255/45s all around on a staggered setup. it looks terrible but I get my replacement wheel today so I can get my set on it!
Consider 255/45/18 front - the rear size, and 285/40/18 rear. I have not yet, but that is the combo I am looking into
That combo will work, I have been running that combo for over 8 years without issue.
I am running 255/45-18 F and 285/40-18 R. Rear circumference difference is 2.36mm smaller in the rear (0.13754% difference).
I am also running 285/40's in the rear on stock mpars for the summer set up. They work perfectly.
I’m with 245/45/ front
285/40 rear 3 yrs so far no issues
|| 1995 740i || M60B40 || DUDMD || ̶o̶r̶i̶e̶n̶t̶ ̶b̶l̶u̶e̶ Mercedes Brilliant Blue Metallic || Style 168 Wheels 1" Spacers ||
Yes. Just showing that "ah it's only 1" makes a massive difference is all.
I've got 245/45 front and 275/40 rear on mpars. Wider rear tire looks correct on the 9.5" wheels, no more stretch compared to 255s.
Current: 2007 Z4 M Coupe (blue/black)
Previous: 2001 740iL Sport (black/black), 2000 528i Sport (black/tan), 1995 318is (black/black), 1991 318is (white/black)
Yeah I drove it for about 20,000km. It didn't like inclines as much and I kept getting "transmission failsafe" or whatever that message is. Never had ISSUES with braking or TC though but.. 27" is the way to go regardless.
Don't have any pics but used to run 255/45 18 on front with 285/40 18 on rear. Looked and handled perfectly in my opinion. Only reason I went back to the 235/50 front and 255/45 rear was tire price at the time. But next set, definitely going back to the 255 and 285 respectfully.
Here are some of the 18" M-par options:
Stock:
Front. 235/50ZR18
Rear. 255/45ZR18
Option1:
Front 245/45/18
Rear 275/40/18
Option 2:
Front 255/45/18
Rear 285/40/18
With these you'll never be out of the +/- 3% for the ABS/Trans/etc...
'01 740i Sport MKIV, Quad Brake Lights, OEM Bi-Xenon retrofit, LED Angel Eyes, HID Fogs, LED Plate Lights, Dinan 7 certification, BM53 radio, OEM Sirius, Aux Input, TCU Bluetooth, Intravee II, iPod, Strong Strut, Dinan Struts, Springs, Camber Plates, Intake, MAF, CAI, Exhaust and Throttle Body
'99 318ti Titanium Silver '97 318ti Boston Green; '96 318ti Alaska Blue (sold); '08 X5 4.8i Titanium Silver (sold); '13 X5 3.5i Black Sapphire Metallic (sold)
'84 633csi Black (sold); '88 325iC Black (sold); '97 740iL Black(sold); '01 740iS Black(sold); '97 318ti Alpine White (sold)
I will ask a possibly stupid question: why?
I have 245 45 18 and 285 40 on my mpars... I'd like to have the 235 50 18s back on the front because the 245 45 sidewall looks a bit small for the front and leaves more fender gap on the stock sport suspension...
Sent from my SM-N910T3 using Tapatalk
I’m definitely running 245/45 and 275/40. The rears could easily handle 285s. I just couldn’t find any at a reasonable price when I was looking.
