Page 3 of 6 FirstFirst 123456 LastLast
Results 51 to 75 of 147
Thread: Mixed E36 Build
  1. #51
    Aug 2012
    Central, MD
    1995 M3
    Thanks!!!! So "C5 FPR" is a Corvette C5 Fuel Pressure Regulator?
  2. #52
    Mar 2012
    Oklahoma
    1997 M3/4/5
    Quote Originally Posted by aeronaut View Post
    Yup. Fits nicely where the stock fuel filter was.
    1997 E36 M3/4/5
    ASM - Slicktop
    My LS3 Build: https://www.bimmerforums.com/forum/s...9#post30117299
  3. #53
    Irwin, Pa
    97 M3, 12 135i
    Quote Originally Posted by wbrentr View Post
    I am going to upgrade the system, but all I did on my build was put the C5 regulator in place of stock filter, run -6 up to LS3 rail, and put a Walbro 460 in the tank. Made 504whp on E85, ran the car the entire season like that. Stock lines. Your way is better.
  4. #54
    Mar 2012
    Oklahoma
    1997 M3/4/5
    Quote Originally Posted by Mark Aubele View Post
    The reason I went with two pumps was to combat fuel starvation issues on the track. This may be overdone a bit, but there will always be fuel being pumped to both sides, either by the stock fuel pump or the return line to the DS.
    1997 E36 M3/4/5
    ASM - Slicktop
  5. #55
    Irwin, Pa
    97 M3, 12 135i
    You didn't overdo it at all, I had to run almost 3/4 tank for it not to starve in right handers.
  6. #56
    Mar 2012
    Oklahoma
    1997 M3/4/5
    Thanks for the confirmation!
    1997 E36 M3/4/5
    ASM - Slicktop
  7. #57
    Mar 2012
    Oklahoma
    1997 M3/4/5
    Not much progress recently. I have been busy with the holidays and picking this up on a fly-and-drive. Made it through 850 miles like it was brand new. Gosh, I love these things.
    1997 E36 M3/4/5
    ASM - Slicktop
  8. #58
    Aug 2012
    Central, MD
    1995 M3
    As far as looks go, that color, door, wheel combo may be the best in bread.
    Don't tell me it's a slick top also.
  9. #59
    Mar 2012
    Oklahoma
    1997 M3/4/5
    Unfortunately not. It did have the factory contour wheels on it which I immediately switched out for the LTWs I had in the attic.
    1997 E36 M3/4/5
    ASM - Slicktop
  10. #60
    Mar 2012
    Oklahoma
    1997 M3/4/5
    So, uh, got the car finished. I have more time on my hands while WFH, so figured I would check on this thread. No movement, ha.<br>
    <br>
    1997 E36 M3/4/5
    ASM - Slicktop
  11. #61
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    First I've seen your thread - surprised, but now realize you posted this not in the Engine Swap section! (where I hang out)
    Very clean build and interesting aspects.
    Kudos!
    E36's are becoming rare!
  12. #62
    Vancouver, BC Ca
    1993 325is
    That car is sooo clean. I love it. Did you stick with the 285s in the front? I don't see the front flares on there.
  13. #63
    Mar 2012
    Oklahoma
    1997 M3/4/5
    Thanks, guys.
    No, I ended up going with 255's of 9" wheels up front. I really didn't want to cut my fenders to make the 285's fit, plus the added stress on the wheel bearings, etc.
    1997 E36 M3/4/5
    ASM - Slicktop
  14. #64
    Mar 2012
    Oklahoma
    1997 M3/4/5
    I tried to get this thread moved to the engine swap forum, but didn't get a response from the mods.
    Plenty of steering input angle:
    1997 E36 M3/4/5
    ASM - Slicktop
  15. #65
    Mar 2012
    Oklahoma
    1997 M3/4/5
    While waiting on my driveshaft to be fixed (yoke was leaking), I decided to make a fan shroud for my radiator. I don't know why Mishimoto's isn't sealed, it's worse than factory. First time making something like this and I think it came out well considering I don't have a welder. Made it through some layoffs so I may snag a mig/tig combo.
    Sealed around the edges w/ some aluminum tape to ensure all air flows through the radiator.
    1997 E36 M3/4/5
    ASM - Slicktop
  16. #66
    Mar 2019
    Milwaukee, WI
    '99 LS-swapped 323i vert
    First I am seeing of this build, too. Very nice!
    Kind of a side note, but may I ask what you did about your A/C setup? (I am trying to get my lines sorted out now.)
    Diving in at the shallow end!
  17. #67
    Mar 2012
    Oklahoma
    1997 M3/4/5
    Quote Originally Posted by motorV8ed View Post
    I'm not running A/C. Goal was to get the car on the road and enjoy it. I will probably add A/C sometime this summer though. I'm not sure which compressor I will be using; I think I can use the GM, BMW, or an aftermarket. I haven't researched it much, obviously. Let me know if you figure out your a/c system.
    1997 E36 M3/4/5
    ASM - Slicktop
  18. #68
    Mar 2019
    Milwaukee, WI
    I reached the same decision last year, viz., get the car on the road late last summer sans A/C, and let the A/C be the project for this spring.
    Sure, I'll let you know how my attempt turns out. I wrote up what was turning into a mini-threadjack here, so I decided to post it on my own build thread instead, and just give the link here: https://www.bimmerforums.com/forum/s...7#post30472687
  19. #69
    Mar 2012
    Oklahoma
    1997 M3/4/5
    It's funny how quick the shallow end becomes the deep end. I was reading your thread last night but got too tired and went to bed. It will be reading while I recover from my morning run.
    1997 E36 M3/4/5
    ASM - Slicktop
  20. #70
    Mar 2012
    Oklahoma
    1997 M3/4/5
    Something I may have to do is to add flaps to the shroud. That was air flow isn't restricted at high speeds where the fan doesn't flow enough air. Simple rubber flaps, or similar, should do that trick.
    1997 E36 M3/4/5
    ASM - Slicktop
  21. #71
    Mar 2019
    Milwaukee, WI
    I must say, it didn't strike me that the shroud as you built it was going to help. To me, it looks like it will restrict airflow, not help. Yes, with your shroud, all the air that goes through the fan will go through the radiator, but ONLY that air will go through the radiator.
    I confess I do not know any of this for sure -- just seat of the pants.
  22. #72
    Mar 2012
    Oklahoma
    1997 M3/4/5
    It is to help out with idling. So, at a low speed, you are pulling air through 100% of your radiator, not just where your fan is located. I'm assuming it restricts it at speeds about 30 mph or so.
    I have some testing to do this week and as temps are going to get near 90, it should give me some good data.
    1997 E36 M3/4/5
    ASM - Slicktop
  23. #73
    Mar 2019
    Milwaukee, WI
    I see. In that case, can you stand it off from the radiator a little? To create some room for airflow from the shrouded area to the fan?
  24. #74
    Mar 2012
    Oklahoma
    1997 M3/4/5
    Yeah, it's offset by about 3/8"
    1997 E36 M3/4/5
    ASM - Slicktop
  25. #75
    Mar 2019
    Milwaukee, WI
    I see. Cool! (Pun not-fully intended. )
  1. E36 Mixed E36 parts
    By Jayzar in forum Car Audio & Electronics
    Last Post: 10-16-2013, 12:49 AM
  2. E36 FS: BMWCCA SPEC E36 Build - 1997 328is (South Carolina)
    By Hellrot99M3 in forum Race Cars & Track Parts
    Last Post: 03-20-2012, 12:58 PM
  3. E36 FS: BMWCCA SPEC E36 Build - 1997 328is (South Carolina)
    By Hellrot99M3 in forum 3 series & Z Series
    Last Post: 03-04-2012, 05:55 AM
  4. Spec E36 build current picture and the Jaffster knob!
    By S.Lang in forum Track Car Builds
    Last Post: 12-01-2007, 04:09 AM
  5. Mixing E36 and E46 RSMs?
    By paul e in forum 1992 - 1999 M3 (E36)
    Last Post: 07-17-2002, 09:07 AM
