I have a 2001 540i and the key remote does not lock or unlock the doors. I even bought a new key from BMW. If there is someone who has any ideas please share them with me. I am in Markham, Ontario, Canada
Sounds like you need to re program your remote.
1) Insert key into the ignition and turn it to the first position, turn back off within 5 seconds.
2) PULL THE KEY OUT OF THE IGNITION.
3) Press and hold the unlock button, then push the BMW roundel (lock button) 3 times, pausing for about 2 seconds in between each press. Release the unlock button. The doorlocks should now cycle between lock and unlock. Now your key is programmed to your car.
4) Re-insert the key into the ignition, turn forward to position 1 and back off within 5 seconds to End programming.
I tried all that and it still does not work. I went to the dealer and the service guy told me it would be too expensive to fix
Moved to E39 forum from BMW Employee and Technician Talk
Note: BMW Employee and Technician Talk is NO MECHANICAL QUESTIONS FORUM! If you have a mechanical question please post in the model subforum. This forum is for BMW techs to talk with each other NOT to answer your car questions. Thank you
Check the fuse in the trunk for the fuel door lock. I found that mine was blown and would blow after replacing it. I unplugged the fuel door lock and solved the problem (although the fuel door doesn't lock with the car now).
Edit: I believe it's fuse #53, a 7.5 amp fuse that goes bad indicating a bad fuel door actuator.
