Results 1 to 6 of 6
Thread: Cooling fan (320d 100kW)
    Jul 2017
    Slovakia
    BMW E46 320D
    Hello,
    could someone, please, tell me how exactly cooling fan works? I want to know at which temperature fan starts and which direction should it spin?
    Is air pulled in from outside of engine bay or is pulled out from engine bay?
    Thanks for any advice
    Apr 2015
    Netherlands
    2000 E46 328i
    Air always comes in, or is sucked in, from the front of the car into the engine bay. Otherwise it would not work while driving.
    Jul 2017
    Slovakia
    BMW E46 320D
    I have some problem with that. Fan does not start so I tried to connected it directly to 12V and used to switch to on/off it but it spins in direction to pull out air from engine bay even during drive.
    Apr 2015
    Netherlands
    2000 E46 328i
    Then you may have mixed up the + and - on your electric fan.
    Jul 2017
    Slovakia
    BMW E46 320D
    I thought that problem was in that but if I change + and - nothing happens. Before connection I measured voltage on pins and I think it is connected in right way.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
  1. year 2000 320D 100kW M47 pressure in cooling system
    By henri090 in forum 1999 - 2006 (E46)
    Last Post: 03-26-2014, 01:27 PM
  2. Considering installing an Electric Cooling Fan
    By tommymats in forum 1992 - 1999 M3 (E36)
    Last Post: 10-02-2001, 12:59 PM
  3. is there anyway to use an electric cooling fan?
    By BJO in forum 1992 - 1999 M3 (E36)
    Last Post: 09-07-2001, 01:23 PM
  4. Auxiliary cooling fan relay?
    By BP SCM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-29-2001, 01:48 AM
  5. Auxiliary Cooling Fan is Not Coming on!
    Last Post: 07-27-2001, 10:29 PM
