Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 103
Thread: Boosting the 2000 Z3M
  1. #76
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Quote Originally Posted by rf900rkw View Post
    Based on a few cues in the pic, I would guess.
    https://www.harborfreight.com/7-piec...set-96363.html
    Sceery...
  2. #77
    Nov 2017
    Oklahoma City
    2000 M Roadster
    I just noticed, literally 5 minutes ago, that the S52 that I picked up is missing a sensor compared to the one that is had. See pictures below. Do you guys know off hand what it is?
    Z3M Engine
    M3 Engine That Got
    Update:
    Headers are on. Going to work on getting the pilot and throw-out bearings installed. Followed by the clutch install. Hopefully I can get everything back in the car this weekend. Supercharger kit is expected to arrive Monday.
  3. #78
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E39/2 E46
    Z3M has an oil temp gauge that needs a sender. Use the oil filter housing and Vanos hose from your old motor.
  4. #79
    Nov 2017
    Oklahoma City
    2000 M Roadster
    Dec 2007
    Great Dismal Swamp
    The alternators are different, also.
  6. #81
    Nov 2017
    Oklahoma City
    2000 M Roadster
    I noticed that long ago but didn’t think it was a big deal. That oil filter housing looks huge. Well back to work.
  7. #82
    Nov 2017
    Oklahoma City
    2000 M Roadster
    Super easy. I got a question, I probably know what you are going to say. Can I keep the gasket? It will be probably Saturday or Tuesday before the dealership can get it in.
  8. #83
    Dec 2007
    Great Dismal Swamp
    No. That gasket is the number one leak source. I buy them in lots. The same gasket is used for all M5x and S5x engines, covering nearly 20 years. Your dealer should have plenty in stock.
  9. #84
    Nov 2017
    Oklahoma City
    2000 M Roadster
    These two rings came with the clutch kit. What are they for? I didn’t see any references when reading DIY write ups online.F87AC9B2-E0F8-4371-8217-2DE7E5AD1AE4.jpg
  10. #85
    SW Florida
    If they're the same size, they look like the "gaskets" that go between the mid-pipe and mufflers, but I cannot imagine why they'd be included with a clutch kit.
  11. #86
    Nov 2017
    Oklahoma City
    2000 M Roadster
    I thought that too. O well. Supercharger kit came in. At a stand still. I didn’t receive any bolts for the pressure plate. BMW will get them in on Tuesday. Could I use grade 8 hex bolts or should I wait? I’m just getting impatient.
  12. #87
    Dec 2007
    Great Dismal Swamp
    What's wrong with the old bolts? I do not use hardware store Grade anything.
    /.randy
  13. #88
    Nov 2017
    Oklahoma City
    2000 M Roadster
    Had to extract one out cause it rounded out.
  14. #89
    Dec 2007
    Great Dismal Swamp
    Then a metric socket-head (8x1.25) from the hardware store will suffice. Get two and put them opposite each other for balance. Original bolts are 8.8, so you should be okay.
    /.randy
  15. #90
    Nov 2017
    Oklahoma City
    2000 M Roadster
    Update.
    Couldn't find any bolts that would work for the pressure plate. Monday evening I installed the new fuel pump. That was a mess chore. The BMW dealership received the pressure plate bolts on Tuesday. Got the clutch finished and transmission mounted Tuesday evening. Got the engine in the car Tuesday night. Tonight I got the power steering system hooked up.
  16. #91
    Nov 2017
    Oklahoma City
    2000 M Roadster
    I have question. Can I delete the vacuum line from the fuel filter to the manifold? I assume it is only there for emissions. I will cap the manifold and have the fuel side open to the atmosphere.
    SW Florida
    I think you mean the pressure sensing line for the fuel pressure regulator. What do you think?
  18. #93
    Dec 2007
    Great Dismal Swamp
    Quote Originally Posted by Randy Forbes View Post
    Sceery...
    This is a good place for that quote. Not only is the line necessary, put clips on the ends. If it blows off, you can melt a piston. Blowing off is not likely at the low boost of this kit, but I don't play games with critical boost sensing lines.
    /.randy
  19. #94
    Nov 2017
    Oklahoma City
    2000 M Roadster
    Thanks. Can you explain what it does? Does it help govern the amount of fuel supply?
  20. #95
    Dec 2007
    Great Dismal Swamp
    Thje line is a reference for the fuel pressure regulator. People, including "educators" whose self-importance far exceeds their worth, will tell you it's to boost fuel pressure under load. That is not the case. The fuel injectors live with their discharge ports inside the manifold. This line supplies the fuel pressure regulator with a manifold pressure reference so that the pressure drop across the injectors is a constant 3.5B. There is easily a 20psi swing between manifold pressure and ambient, cruise vs WOT max boost. This line makes sure the fuel pressure as seen by the injectors is constant.
    /.randy
  21. #96
    Nov 2017
    Oklahoma City
    2000 M Roadster
    Thanks Randy. I always appreciate your knowledge.
  22. #97
    Nov 2017
    Oklahoma City
    2000 M Roadster
    I may use an adhesive such as super glue to keep it on since their are no hose clamps that small. If I need it off I can cut the tubing and put in a plastic coupling.
  23. #98
    Dec 2007
    Great Dismal Swamp
    Your hardware store will have several styles of clamps that will work. Spring clamps, not worm clamps. All of mine are clamped. Well, except the ones that were changed to compression fittings.
    /.randy
  24. #99
    Nov 2017
    Oklahoma City
    2000 M Roadster
    Guys. I got the motor back in and the supercharger hooked up.
    I tried to start it the first time. It rolled over but stopped. Apparently I did not clip in one of the fuel lines all the way so it was puking out gas.
    Fixed that in 5 seconds. When I tried to start it the second time it made a click sound "as if the solenoid on the starter engage" but then all the power for the entire car shuts off.
    I had to disconnect and reconnect the positive terminal to get power back on. I tried it a third time and it did the same thing. Before I keep doing this over and over again, what do you guys think I need to try.
    Could it be a ground? I'll check but there were not that many grounds from what I remember.
    What I don't have connected are the rear O2 sensors, front bumper, and radiator. I wanted to see the car run before I put them back on. Regardless this should not hinder the start up.
  25. #100
    Nov 2017
    Oklahoma City
    2000 M Roadster
    Update. Got power but know when I try to start the car it just clicks and it sounds like it is from the starter. Does even try to roll.
  1. dumb question: Where is the leak detection pump on a 2000 Z3M Coupe
    By sevenracer in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 12-01-2017, 07:20 PM
  2. where is the starter and fuel pump relay 2000 Z3M?
    By mnguyen84 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-15-2015, 09:05 PM
  3. Is the lowbeam bulb for the 2000 MCoupe an H7?
    By HamannPerformance in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-11-2008, 08:43 PM
  4. Replies: 19
    Last Post: 01-20-2003, 12:01 PM
  5. Engine in the 2000 323i wagon
    By bungy42 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-12-2001, 12:02 PM
