Page 2 of 5 FirstFirst 12345 LastLast
Results 26 to 50 of 103
Thread: Boosting the 2000 Z3M
  1. #26
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Quote Originally Posted by ShelbyGT500 View Post
    Attachment 624826
    Will this work for the S52?
    Got a dumb question. Could I reuse the ARP studs on my other engine when the time comes? Wasn't sure if these were a one time use stud.
    That's the right cam tool set for an S-52 single VANOS engine.
    The value of ARP head (main) studs is that they're reusable__otherwise, why pay 3X the cost of one-use TTY bolts, unless you expect to rebuild the engine more than once (plus they have higher tensile strength, desirable with forced induction).
  2. #27
    Nov 2017
    Oklahoma City
    2000 M Roadster
    Update: Received AA headers, Clutch, & Picked-up the engine
  3. #28
    NY
    skateboard
    Nice
    ― George Orwell
  4. #29
    Nov 2017
    Oklahoma City
    2000 M Roadster
    I am currently stripping down the engine (i.e. Manifold, harness, etc.). I noticed a huge rust spot and wanted to ask a question. Would this rust spot be caused by the plug leaking coolant?
    Working on changing the water pump and power steering pump while I wait for the gasket kit and tools to come in. I still need to purchase head studs.
  5. #30
    Nov 2017
    Oklahoma City
    2000 M Roadster
    Anybody know the bolt size to remove the water pump?
  6. #31
    TX
    97 M3/4/5, MCS
    10mm. Also ,if it is stuck on there, you can actually take the bolts and there are two holes that are threaded that will work the water pump out.
  7. #32
    Nov 2017
    Oklahoma City
    2000 M Roadster
    Sorry for not being clear. The question was directed to the thread/size for the bolts to push out the pump. Regardless never thought of using the same bolt that holds it in place. Great idea sir.
    I got bolts that worked on the new pump but they were to big on the old pump.
  8. #33
    SW Florida
    Really, you use two (2) of the M6 bolts that secure the thermostat housing, as the waterpumps__all the ones I've changed__are held on with studs & flanged nuts.
    Nov 2017
    Oklahoma City
    2000 M Roadster
    Damn wrench doesn't fit.
  10. #35
    Nov 2017
    Oklahoma City
    2000 M Roadster
    Modified the tool. Timing gears are off.
  11. #36
    Nov 2017
    Oklahoma City
    2000 M Roadster
    No Good
  12. #37
    May 2015
    savannah, ga
    2000 m roadster
    That sucks. I hope that something that is soft enough to drill. I once had an intake bolt break off in a head. I tried to easyout it and the easyout broke too. Once that happened I was screwed. I tried everything for a day and failed. I ended up changing the entire head.
  13. #38
    Nov 2017
    Oklahoma City
    2000 M Roadster
    I don't think it in fucked yet. Need easy out the bolt. Head is off though.
  14. #39
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    That there is what never changing the coolant looks like. Tis the first time I've seen the head gasket leak at the water port.
    Do not drill or try an easy out. Lightly heat the aluminum with a propane torch and wind the nub out with baby vise grips.
  15. #40
    Kent, Ohio
    1998 M Roadster
    Quote Originally Posted by rf900rkw View Post
    Just remember the melting point of aluminum is 1221 degrees F.
  16. #41
    Nov 2017
    Oklahoma City
    2000 M Roadster
    Thanks guys. It was pretty nasty. Spent the last 3.5 hours cleaning the block and head with razor blade and brass brush. You guys were right with recommending the head gasket replacement.
  17. #42
    SW Florida
    When there's no stub to grab with baby vise-grips, a left-handed drill bit is the best easy out I've ever used__of course a reversible drill is a must too! I gave up using so called Easy-Outs more than twenty (>20) years ago, they just cause more problems.
    Using a left-hand drill bit heats the stud as it drills__RH bits do it too__but at some point the bit bites into the stud and unwinds it from the hole. It's worked every time.
  18. #43
    Dec 2007
    Great Dismal Swamp
    That broken bolt end is going to be corroded in. It's going to take heating.... 250-300F, no where near the tempering point let alone the melting point. Don't force the bolt. Keep wiggling until it starts to move then wind it out with a back and forth motion. If it starts binding again, let everything cool down (the aluminum will cool much faster than the steel causing it to wedge). And start over.
  19. #44
    Nov 2017
    Oklahoma City
    2000 M Roadster
    I heated the crap out of the bolt and it's still bound up. No play whatsoever. The vice grips is tearing the bolt up. I soaked the bolt in PB blaster for the night. I'll try again with the heating process. I won't be as aggressive with the vice grips this time.
    Check out the old water pump that I pulled Friday.
  20. #45
    Dec 2007
    Great Dismal Swamp
    Don't heat the bolt, heat the aluminum timing cover. You want to expand the aluminum, not the steel.
  21. #46
    Nov 2017
    Oklahoma City
    2000 M Roadster
    Well I have some shitty news. All the tips and tricks did not prevail on this stud. The stud did not want to budge after several heating cycles and two nights worth of soaking in PB blaster. I punched and drilled the stud to use an extractor. Everything was going good until the tip of the extractor sheared. I contacted a machine shop and they believe it will be a chore to extract the stud with the hardened tip stuck in it.
    My thought is that I could get a new timing chain cover and swap it out with the one that the stud broke in. I read a write up on here and it doesn't seem that bad to swap out considering the progress I already made on this engine. I feel like this would almost be as cost effective than having the machine shop mess with it. I assume I need to change that gasket, but can I reuse those bolts or should I get new ones?
    My next item that I would like to seek advice on. How should I clean the block and head surfaces that will mate up with the gasket? Below is the process I used. I didn't want to be to overly aggressive on the aluminum.
    (1) Razor blade to scrape off gasket material and large chunks of gunk.
    (2) Several hours of brake cleaner and small brass brush. (Still had areas of "coking" that were not coming off)
    (3) Fine scotchbright pad.
    (4) Aluminum polish.
    The surface still looks discolored, versus the nice polished aluminum look. It is very smooth besides the few spots where "coking" has occurred. How should I proceed? I would like to avoid the machine shop and having to take out the rotating assembly.
    Oct 2014
    North Jefferson
    2000 M Roadster
    Can you find someone with an EDM for the broken stud and extractor? Occasional miracles can be had with EDM.
    Call me Mel. Some years ago- never mind how long precisely- having little or no money in my purse, and nothing particular to interest me at home, I thought I would motor about a little and see the other parts of the world. It is a way I have of driving off the spleen and regulating the circulation.
  23. #48
    Mar 2016
    Blairstown, NJ, USA
    1998 M Roadster
    If you have access to a MIG welder, weld a nut onto the remainder of the stud. The interior diameter of the nut should be slightly smaller than the diameter of the stud. Wiggle the nut back and forth and heat the aluminum per Randy W's suggestion. The nut might shear off--try again.
    Wayne
    1998 M Roadster
    1994 Honda ST1100--sold
    2017 Yamaha FJR1300ES
  24. #49
    SW Florida
    Classic/textbook outcome. Extractors work by forcing themselves into the hole you drilled and the more you tighten them into the stud, the harder it works to expand the stud into the hole it's already stuck in. Then the hardened stud extractor breaks off in the stud. Predictable outcome.
    I use left-hand drill bits, and in the rare case when it can't back the stud out, I keep progressing with incrementally larger bits until there's no grip left and clean up the hole with a tap.
    Starting__and keeping__the drill bit centered is paramount.
    Moving on...
    I've only used this practice on cast iron blocks, but with care, I don't see why you couldn't clean up an aluminum one too. You're not removing any appreciable amount of material, but maintain even and consistent strokes, equal pressure maintains itself.
    Go to any local granite countertop place and ask if they'll give you one of the drops. Offer them a few bucks to square it up and give you at least one (>1) polished flat surface. Mine's a bit larger than an 8 x 11 sheet of sandpaper.
    Properly clean afterwards.
    Most of the time, it's used like this.
  25. #50
    Why hadn't I thought of that... who needs a machine shop anyways?
    PRICE CUT on ALL FABRICS
  1. dumb question: Where is the leak detection pump on a 2000 Z3M Coupe
    By sevenracer in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 12-01-2017, 07:20 PM
  2. where is the starter and fuel pump relay 2000 Z3M?
    By mnguyen84 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-15-2015, 09:05 PM
  3. Is the lowbeam bulb for the 2000 MCoupe an H7?
    By HamannPerformance in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-11-2008, 08:43 PM
  4. Replies: 19
    Last Post: 01-20-2003, 12:01 PM
  5. Engine in the 2000 323i wagon
    By bungy42 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-12-2001, 12:02 PM
