Results 1 to 4 of 4
Thread: 2004 530i crank shaft position sensor circuit A fault
    Apr 2009
    Morganton, NC
    2000 740i Sport Imola
    I know that there are a number of posts regarding this (I have scoured the net) but I am at a loss. What began as an intermittent issue now has my car dead in my driveway. I scanned the car and received the crank shaft position sensor circuit A fault error. I changed the sensor with an aftermarket sensor and nothing changed. I then put in a bmw sensor and still no change. I have no pressure at the fuel rail when the key is turned on. I can not hear the pump kick on when the key is turned to on. I have not yet checked for voltage at the pump. Is it possible to have a bad pump and not get the fuel pump error notification? The car turnes over and will sputter occasionally but will not idle. Can a fuel pump problem show as this code? I don’t want to beat a dead horse but my next stop is the shop. Any help is appreciated.
    Apr 2016
    Philadelphia
    1997 m3
    Yes you can have a bad pump with no code. You wont get a code on older cars. Check for voltage at the pump and go from there. Check fuses etc.
    Aug 2014
    Los Angeles, Ca
    89 E30 S52 94 E34 S52
    Aftermarket sensors can give you bad results too with no code,
    Feb 2010
    Atlantic Beach, Fl
    81,e21 orig ownr&05,e60
    Assume the crank position sensor is properly seated. They can be a bear to get seated properly, with no indication it isn't in. Other than not starting.
  1. crank shaft position sensor
    By fenderls in forum 1988 - 1996 (E34)
    Last Post: 08-02-2009, 05:21 PM
  2. Crank Shaft Position Sensor, NEW $47 shipped
    By lemond in forum Engines, Performance Parts & Software
    Last Post: 06-24-2009, 04:02 PM
  3. FS: OBDII crank shaft position sensor
    By G60 CAB in forum Engines, Performance Parts & Software
    Last Post: 02-23-2009, 12:14 PM
  4. Crank Shaft Position Sensor
    By malibu73 in forum 1991 - 1999 (E36)
    Last Post: 10-27-2007, 11:00 PM
  5. crank shaft position sensor?
    By Toxic0n in forum 1991 - 1999 (E36)
    Last Post: 04-28-2007, 10:47 PM
