Results 1 to 10 of 10
Thread: Homelink swap?
    Jul 2013
    Chicago
    2001 740iL Silver/Grey
    Homelink swap?
    Where does the homelink save the codes? Could I just swap the unit from one car to the other? I’m having problems getting the new car to read the garage opener signal. Seems like a silly waste of time, but I tried syncing the new unit for about 30 minutes to no avail.
    NYC
    99 IL/13 SXT/04 Audi A4
    Quote Originally Posted by armiller1 View Post
    Yes u can and them reprogram the new homelink
    El Cid 1999 IL
    DUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
    Jul 2013
    Chicago
    Quote Originally Posted by franco90 View Post
    Wait, what? Are you saying the codes will stay with the old homelink? If I swap in the old one, it’s coming from a parts car. So the new one would be useless.
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    The HOMELINK unit has an IC board inside of it...the code is saved to the HOMELINK unit. Just like the GDO (garage door opener) fobs that came with the opener hanging from your garage ceiling...you can move them to any other vehicle because they are coded specifically to your GDO. The same with the HOMELINK...it has been coded to your GDO...and if the data hasn't been erased...it will continue to transmit the code it was programmed to transmit.
    I wonder how volatile the HOMELINK's memory is? Will it remain programmed indefinitely if removed from electrical power? Or will it keep the memory for a limited amount of time (minutes/hours/days/weeks/months/years)?
    Also, there are multiple HOMELINK units that operate on different frequencies for different ranges of time. The units installed in the early e38s had buttons that were unlit & had a red status LED when the buttons were pressed. Then around the mid 90s the GDO frequencies changed industry-wide...so the HOMELINKs had to change to keep up and the buttons became lit (illuminated) and the status LED changed to amber and/or green during the later e38 production.
    Then GDO frequencies changed again around 2010/11...so if you have a new Chamberlain or Liftmaster GDO...your old UGDO (universal garage door openers aka HOMELINKs) may not work with the new GDOs...and you will have to get a "bridge" unit (repeater) that will allow your old UGDO to work with the new GDO.
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Yeah, according to my 2 year old GDO, I need a repeater to work with e38. Maybe OP has similar issue?
    Current: 2007 Z4 M Coupe (blue/black)
    Previous: 2001 740iL Sport (black/black), 2000 528i Sport (black/tan), 1995 318is (black/black), 1991 318is (white/black)
    NYC
    Quote Originally Posted by Ruskii View Post
    Homemade super range extender here!
    http://www.bmwtips.com/tipsntricks/H...geextender.htm
    BMW Universal Transmitter (Garage Door Remote) Programming Instruction
    http://www.bimmerboard.com/forums/posts/689
    El Cid 1999 IL
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Thanks franco, I am going to try the instructions in the second link this weekend!
    Jul 2013
    Chicago
    Yeah, thanks guys! You’ve given me way more info than I imagined I could get. I will swap them and see what happens.
    Jul 2013
    Chicago
    The swap was a piece of cake. It took 3 minutes and the old homelink still works after sitting for a few months with no battery attached.
    (northeast) Indiana
  1. Has anyone doen the auto to manual tranny swap?
    By DeezBMW in forum 1991 - 1999 (E36)
    Last Post: 04-03-2001, 09:44 AM
  2. Swapping E34 M5 motor to E36 M3
    By loday in forum 1992 - 1999 M3 (E36)
    Last Post: 03-08-2001, 03:27 PM
  3. M3 engine swap
    By Vok in forum 1991 - 1999 (E36)
    Last Post: 03-06-2001, 10:35 PM
  4. Tranny Swap
    By SAMiAM in forum 1983 - 1991 (E30)
    Last Post: 03-01-2001, 02:17 PM
  5. kidney swap 95 to 97 +? (new b ?)
    By rockstar in forum 1991 - 1999 (E36)
    Last Post: 02-27-2001, 08:49 PM
