Results 1 to 6 of 6
Thread: is it normal
    kissimmee fl
    92 325i
    Question is it normal
    hello to all
    a few weeks ago i purchase a 02 325xi sedan it needs a little tlc. my question is the heat works great, but my only concern is it normal when you park and leave the car idling and after a few minutes the heat feels luke warm.?? until you start driving again.
    Jan 2016
    Ca
    2001 525it
    Could be the thermostat is stuck open If you had a check engine light on and the fault was for thermostat stuck open, well there ya go or if the engine temperature needle is left of 12 o'clock then that would indicate a faulty thermostat. But these gauges are buffed to reduce the amount of needle movement, don't want to freak out the consumer. If neather of those ideals exist, use an infrared heat to red the temps at the upper & Lower hoses, coolant goes into the engine at the lower hose and comes out thru the top hose
    Mar 2018
    Ohio
    2001 BMW 325xi, e46, m54
    also consider the temperature outside. A lot of cars iv driven during the winter do not get all that hot. Especially if youre just idling. If your just sitting at idle blowing super cold air past your heater core its only gonna get so warm. I would say that as you are driving you would get better heat. But as suggested above, DO check your thermostat. Cant imagine you would want to take chances with your engine cooling system since that is what controls the temperature of the heat in your car
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Google “BMW E46 hidden OBC functions.” Test #7 will show the coolsntvtemperature as seen by the engine computer (DME). It needs to be in the 95*C-100*C range. If it’s low the thermostat is likely bad. The cooling system is the Achilles heel of the E46. It needs to be kept in tip top shape. Never buy afternoon cooling system parts as you’ll end up with an overheated engine.
    May 2017
    2009 BMW 328i E90 N52B30
    Hello guys, my 2009 E90 328i 52 is runing at 112 F / 99 C.
    Ambient temperature is 75 F / 24 C.
    Isn’t that hat too much?
    DTC Fault Codes after replacing valve cover.
    https://www.bimmerforums.com/forum/showthread.php?2372252-Many-DTC-Fault-codes-after-replacing-valve-cover
    Rod Lequerica. - Miami FL
    2009 BMW 328i E90 LCI Sedan Type PH77
    Engine: 6cyl 3lt N52B30A - Auto Trans: GM GA6L45R
    VIN WBAPH775X9NM Plus 5 last serial numbers
    EL_LEQUE_DELAE@YAHOO.COM
    +1 (786) 239 1329)
    May 2017
    Quote Originally Posted by MarcoZandrini View Post
    If 203-212F /. 95-100C is s the correct temperature.
    (Just below water evaporation temperature)
    Coolant Temperatures specifications in proportions are:
    50% / 50% ; 228F/ 109C
    66% / 33% ; 221F / 105C
    so if my car runs at:
    212F / 100C at 40 mph
    240F / 115C idling
    what happens to the coolant and the car above 109C ?
    +1 (786) 239 1329)
  1. 98 ///M3 clutch issue,is it normal !
    By Yasir in forum 1992 - 1999 M3 (E36)
    Last Post: 07-18-2003, 12:43 AM
  2. Is it normal for a Valentine One to throw a lot of falses in the city?
    By DSK M3/4 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-18-2003, 05:35 PM
  3. Is it normal for my engine to sound like X?
    By Extratx in forum 1992 - 1999 M3 (E36)
    Last Post: 03-07-2003, 08:54 PM
  4. Is it normal to be fed up with the boot cover after 2 uses?
    By Hugo in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-17-2002, 08:56 AM
  5. Is it normal for new brake setup to squeal?
    By vroo//M in forum 1992 - 1999 M3 (E36)
    Last Post: 07-09-2001, 11:18 AM
