What's up guys my buddies looking to do a headgasket and get his car ready for boost he was going to get a stock thickness headgasket but I suggested a .140 thickness. All we can find in that thickness is the 87 mm bore headgaskets. Is that the one he should run or no?
Sent from my SM-G935V using Tapatalk
If you can't find the correct bore I would think cometic stopped making them? Everyone seems to be the copper spacer/ cutring combo instead of the MLS these days
look into it
I ended up buying a cutring I've heard too many MLS gaskets being hit or miss with boost
Sent from my SM-G955U using Tapatalk
VAC's website markets their MLS gasket as "up to" an 87mm bore. I don't have experiences with running a larger bore MLS, but hopefully someone else can chime in.
I'm planning on running e85 with my stock s50 one for now and seeing how it holds up.
