i have the 2001 bmw 330i sedan, it has the factory harman kardon premium sound navigation system with factory amp in trunk, i cant find any info online for my specific system, all the ones ive viewed have a single din unit with 1 connector plug with antenna plug, mine has 2 connectors and no antenna plug, i bought the d5150 headunit im trying to install, the connector i orderd for my vehicle doesnt plug into my factory connectors, its for the single din one, mine is a double din.. il try to post pix to help understand what im talking about, i need to know what kind of connector i need n where to get it, or do i have to splice wires from amp n run them to the front to the harness off the new headunit... any help would be greatly appreciated!
THIS IS FACTORY HU
THESE ARE THE ONLY CONNECTORS
AFTERMARKET HU
BACK OF NEW HU WITH HARNESS
THIS WAS HARNESS THEY GAVE ME, DOESNT CONNECT TO MY FACTORY CONNECTORS "BLUE & WHITE ONES"
The head unit in your car is merely the human-machine interface. All of the actual electronix are in the trunk!
Hi,
You bought that 'Enono' unit right? .. that 'brand' with it's proper spelling is banned from being mentioned on this forum as when they sponsored, so MANY members got useless, failed, failing units and little to no support that the site owners got fed up and kicked them off. They've been kicked off/removed from at least two other forums too.
You need to buy the 5m extension cable which plugs into the back of the car's wires, and extends the antenna, speaker, power & ground wires to the front.
Lots of threads online about this, so have a search around.
I'd also suggest getting your money back on that low quality Enono unit and buying a reputable, high quality brand unit instead!
Cheers, Dennis!
