Need to replace steering wheel clock spring. How do you remove the clock spring from the steering wheel? Steering wheel is off, air bag removed.
There are 3 tiny nuts (4mm I believe) that hold the clock spring onto the wheel. They should have a dab of yellow or green on them and the spring mounting studs. The nuts and washers are really small, so use caution not to lose them when work is being done.
Bert
91 850i-A
1972 3.5 CSi (L-jet, Getrag 265 5 speed)
1988 ///M6
2021 X3 M40i
The back to back BIG COUPE” duo
thanks; got it
