Page 2 of 2 FirstFirst 12
Results 26 to 41 of 41
Thread: Rear Subframe Attach Reinforcement Brace
  1. #26
    Vancouver, B.C., Canada
    '97 M3
    The rear subframe mods are all installed.
    I have a bunch more to do at the front of the car so I don’t get to test it just yet.
  2. #27
    '97 M3
    Well, she is finally back on the road. As usual there are a couple of loose ends to finish up but at least I’m driving it.
    Now on to the good stuff. Initial impression of the rear subframe forward attach point reinforcements is that the car feels like the engine is directly connected to the wheels. This car has never felt like this as long as I’ve owned it. It’s a massive improvement. I have not had a change to do a hard launch yet but I did a rolling second gear burnout by punching it in second with the traction control turned off. It was smooth and straight. The RE71Rs didn’t have a chance at holding that.
    More to come, I’ll put the GoPro under the back of the car to compare before and after subframe movement....
  3. #28
    Mar 2001
    Oregon
    95 s/cM3,93 332is turbo,96 chevy dually, 73 camaro
    Where do I place my order? Hope you or someone comes up with a kit for the rest of us.
  4. #29
    '97 M3
    I made templates.
  5. #30
    '97 M3
    I’ve been scared to do a hard launch, just incase are the rear subframe attach work didn’t fix the hop, but......... she is tight. Those poor RE71Rs got lit up a bunch of times from a launch first at 2000 rpm, then 3000 rpm and then close to 4500 rpm just to be brutal. Nice smooth black stripes and only a slight remenisant feeling of hop as it was bouncing off the rev limiter (not hop). Yay, I finally won that battle. Screw you hop!
  6. #31
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by chikinhed View Post
    Huge success man!
    I think your chassis was in need of it. Still amazed you popped those welds.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  7. #32
    '97 M3
    I think the popped spot welds are more common than people think. People just aren’t looking for them. Another local guy was ribbing me about the crack and spot welds so I looked in his car and pointed out the popped spot welds in his car. His is a 328 that he uses for HPDE and is NA.
  8. #33
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    I finally got the reinforcements installed along with the subframe, suspension, diff and gas tank. I’m also halfway through modifying an e46 M3 finned diff cover for the 210 diff in the e36 subframe.
    I still have a bunch of stuff to do but at least I have some progress.
    Those two holes in the part that drops down. Do they mount to the subframe?
    You should have a guy like Rally Road remake these and give you some money for your design.
    Or I'd gladly buy this from you. You did a great job and I am glad it fixed your issue.
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  9. #34
    '97 M3
    The two holes in the black piece bolt through the angle side of the subframe attach box section to stop it from flexing up and down at the narrow section where the driveshaft passes through. Mine flexed so bad that I had a five inch long crack there. It still flexed like crazy even after welding up the crack and the popped spot welds and all the additional spot welds I added.
    The only two down sides from this mod so far are the additional weight (sorry Jaker) and I get a bit more driveline noise because there is a 1/4” thick strip of rubber sandwiched between the brace and the forward part of the subframe. The back seat kills most of the noise though.
  10. #35
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    When does production start for the reinforcement kit?
  11. #36
    Vancouver, BC Ca
    1993 325is
    The only down side from this mod so far are the additional weight (sorry Jaker).
  12. #37
    '97 M3
    I will personally inspect your car for cracks if you’d like
  13. #38
    Nov 2009
    Gretna, NE
    2x E46M & 3x E36M
    more pics of e46m cover project? i'm working on the same thing right now, just 3d printed my first prototype.
    you got me wanting to cut off the bottom of my subframe now.... just when i thought i was almost done with this project lol
    check out my eBay store
    E30 - E36 - E39 - E46 - E60 - E92
  14. #39
    Jun 2005
    New England
    I was just reading an article in muscle mustangs & fast fords on subframe braces. Basically from subframe to a suspension mounting point to the rocker on on each side. Have not looked to see whether this could be done on our cars. Goal was to reduce wheel hop. Mustang subframe was observed moving 1/2 inch up and down under extreme stress.
  15. #40
    '97 M3
    The diff cover project will continue. I’m almost at the end of my ‘busy’ season so I can start playing with it again. The next step is make a mounting spot for the VSS. It will be a bunch of cutting and welding and drilling.
    That’s good to hear that stiffening up the attach points also works for other chassis out there. The car did well on the track, no strange behaviours.
  16. #41
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Ah yes, I remember being asked that very same question about fourteen (>14) years ago!
    And just like chikenhed, it all came about as a desire to fix my own cars, and then other enthusiasts wanting to do the same thing. Barely a year later, I had to quit my day job, so the reinforcement business holds a lot of promise!
    Good job!
  1. FS: E36 Rear Subframe & Chassis Reinforcement Kit
    By partsgroup in forum Race Cars & Track Parts
    Last Post: 03-12-2011, 10:36 AM
  2. E36 Rear Subframe Mount Reinforcement Plates
    By JWBrockman in forum Exterior Lighting & Body Parts
    Last Post: 04-12-2007, 11:59 PM
  3. FS: 95 M3 rear subframe with reinforcements
    By John@BPG in forum BMW Parts For Sale
    Last Post: 12-14-2006, 09:21 PM
  4. FS: E36 Rear Subframe/Chassis Reinforcement Kit from Turner
    By KillrM3 in forum BMW Parts For Sale
    Last Post: 09-24-2005, 07:23 PM
  5. E36 Rear Subframe/Chassis Reinforcement Kit
    By ArkticSilber in forum 1992 - 1999 M3 (E36)
    Last Post: 06-04-2003, 02:04 PM
