RM European Auto Parts
Results 1 to 2 of 2
Thread: M3 cluster swap issues
    Aug 2015
    Crystal Lake, IL
    1996 BMW 328i Sedan
    Car is a 1996 328i. The PO decided it would be a good idea to swap in the M3 cluster at some point. However, all the instruments are “off”.
    -the speedo reads 5-10 mph low
    -the tach is definitely off by about 500 revs
    -fuel gauge reads high all the time (yikes!)
    -temp gauge reads slightly to the right at temperature. I installed a backup Autometer water temp gauge.
    I’ve played around in INPA using the KOMBI function but can’t seem to do anything useful. The test function works, I can get all gauges/warning lights to activate and sweep.
    Does the cluster need to be recoded somehow? Has anyone else had this issue with an M3 cluster swap? I suppose I could just go grab an original 328i cluster from the boneyard, but this has been bugging me from the day I bought the car, has to be a way to recalibrate the cluster so it works right.
    Figured I’d just throw this out there for anyone who might have an idea or seen it before. Thx
    Jul 2004
    Houston, TX
    36 Cylinders
    You should poke around NCS Expert program, along with NCS Dummy helper program. Yes, this is for recoding.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  1. Definitive e36 m3 cluster swap thread
    By Alecs MacDonald in forum 1991 - 1999 (E36)
    Last Post: 05-01-2023, 03:51 PM
  2. E36 mileage after m3 cluster swap
    By Itsa328 in forum 1991 - 1999 (E36)
    Last Post: 09-07-2010, 05:39 PM
  3. M3 Cluster swap? Any troubles?
    By SnakeDoctor in forum 1991 - 1999 (E36)
    Last Post: 05-02-2006, 12:31 PM
  4. Euro UK M3 cluster swap - speedo wrong!!
    By EEEEeeee36 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-22-2006, 08:15 AM
  5. Cluster swap issues....
    By hinzm3 in forum 1983 - 1991 (E30)
    Last Post: 01-26-2006, 12:58 AM
