Hey guys ! Passenger windows and the rear driver window don't work . But the driver window works . Any idea fellas ? My rear window is stuck open now and it's supposed to rain tomorrow
1991 auto 850i
Check relays in the driver's side trunk. Swap around if needed. They should be orange/brown. There are about 3 or 4 of them.
What "thumbs up" really means
The driver and passenger side windows have their own power supply and protection circuit. If something is wrong with it (bad fuse, bad relay), the entire side will be dead like is the case with your passenger side windows. Double check fuse F34 in the rear power distribution box. If okay, do as toomanyparts suggested: Swap the K15 and K30 power protection relays (the 2 orange relays sitting next to each other on the top row of the rear power distribution box). If the problem now switches sides, one of both relays is bad.
As to what may cause the driver side rear window to be inoperative, I'm not sure at the moment. Clearly the driver side fuses and power protection relay are fine because the driver side front window works.
Can you close the driver side rear window with the key in the door lock (keep the key in the lock position to automatically close any open windows and sunroof).
Thank you fellas !!! I'm on it first thing in the AM
Back window will not close with the key in the door being held in lock , I know the procedure , I tried it , didn't work . Will try the relays , will update !
So , update - both relays and fuse are good . Guaranteed . I used the relays from my other e31 , they work on it , his does not work on that one . Anything else I should check ? PS there was some moisture inside the cabin when the door windows stopped working , middle compartment area , what's inside the cabin that can cause that issue ? Any help is appreciated !
TheShark850: When you operate the non-working windows, do you hear relays clicking in the luggage compartment (K15/K30 power protection relays) and in the lower driver-side door sill (A5 relay module)? You may need a silent environment for this or a second person listening close to the relays in the trunk.
About the moisture... Maybe the windows/sunroof had not closed entirely resulting in some morning condensation? Or was it around the center console - especially the carpet below the center console? That could point at a leaking heater core (not uncommon on these cars).
But now that you've mentioned moisture, you may want to inspect the A5 relay module (RM) which is responsible for operating the power windows motors. It resides underneath the driver-side door sill carpet. There have been a few cases where clogged sunroof drain pipes caused water ingress into the door sills causing corrosion damage to the modules there. Instructions to get access to the A5 relay module.
Revtor , I love you bud (no I haven't fixed my issue yet as I JUST read your response , but you gave me something new to look at) .
So far the update is this , I've replaced EVERY SINGLE RELAY in the fuse boxes , engine bay and trunk , nothing , I've replaced the General module - nothing again . I've replaced EVERY SINGLE fuse in both boxes - nothing again . So it HAS TO BE what you pointed out , I'm going to go change it right now (I have a second 850 so I've been interchanging all those relays and modules . So I'll update when I do check it !
Yes !!! That's the issue . It seemed like it was in water for a bit and it burned the circuits . I'm a good solderer and this one is sadly not repairable so I already purchased one to replace it ! PS - what's that ECU looking thing which was right next to it on the door sill ? I was appalled to see MORE boards on this car ! I've literally had to repair every one of them pretty much , they just keep popping up of the sheds lol
BIG thanks to everyone that chimed in . Even bigger thanks to REVTOR , I was not sure where else to look , sure enough , the 8 had more hidden compartments with more computers
You mean the metal one right in front of the A5 relay module? That's the A7 or A70 anti-lock braking module (ABS). In the passenger-side door sill you'll find the N1 anti-theft control module (DWA).
Anyway, your main concern at this moment is where did the water come from and how to stop it from getting there. Simply replacing the module might be only a temporary solution.
TheShark850 sent pictures of the corrosion damage. Even though the PCB is conformal coated, the combination of water and electricity (electrolysis) has eaten away component leads and PCB traces:
That's a goner!
My BMW Repair YouTube Channel
I have a few questions; first, does the coating covering the circuits need to be removed before soldering? Is so how, hot air gun? Next, where is the recommended place to purchase the capacitors?
